Shorting plugs "fixed" hum problem on 1000A.
My Sansui 1000A had a strange problem when going from tuner to phono 1, randomly the left phono channel would get a strange hum on it and I used to lower the volume and switch back and fourth 1 or 2 times to clear the problem.
Then one day I accidentally dropped the tone arm while trying to cue a tick or pop to see the location (motor was off) and the left channel started humming.
It seems that a high transit signal hitting the left phono channel tends to "lock up" the input amp and temp. cause a hum problem.
The phono stages are solid state using germanium transistors (I would like to bias them for low noise silicon but haven't figured out how yet) and when going from tuner to phono 1 you have to go though phono 2 first, that is where I put my "home made" shorting plugs (just the ends of a cheap cable with the shield and center twisted together)
Works like a charm, no more "hum" problems.
Going from tuner to the "open" phono 2, then to the "loaded" phono 1 seems to be the problem cause, and the shorting plugs fixed this, otherwise everything works normally.
The phono stages where recapped and the switch was checked out to be OK and was de-oxed" with no change.
Mark T.
