So here is my list, I will edit it as i work out the replacements. If anyone sees anything off, let me know and i can change it. If I have multiple parts listed, it means im deciding between the listed options, there is a lot to consider and Im a bit confused:/ Thanks
The measurements are in this format, DIA., Length , lead Inner, lead outer, were leads bent.
2x 50v 8000µF 31mm, 64.5mm 13.7mm,15.7mm N
UFW1H103MRD
2x 63V 220µF 16mm, 32mm 7.5mm N C403,C404 CEA
UPW2A221MHD
1x 50V 2.2µF 5mm, 11.5mm 2mm Y C416 CEA
UPW2A2R2MDD
1x 50V 47µF 10mm, 16.5mm 5mm N C335 CEA
UPW2A470MPD
1x 50V 220µF 16mm, 25mm 7.5mm N C406 CEA
UPW2A221MHD
1x 25V 100µF 10mm, 16mm 5mm N C408 CEA
UPW1V101MPDAZHTD
3x 16V 47µF 8mm, 12.5mm 5mm Y C336,C125,C407 CEA
UPW1J470MPD
1x 35V 330µF 16mm, 25mm 7.5mm N C405 CEA
UPW2A331MHD1CA
4x 35V 4.7µF 5mm, 12mm 2mm Y C219,C122,C132,C165 CEA
UPW1H4R7MDD
3x 50V 1µF 5mm, 12mm 1.3mm, 2mm Y C124,C129,C142 CEA FILM?
ECQ-E2105JBB
1x 6.3V 220µF 10mm, 12mm 5mm N C164 CEA
UPW1V221MPD
5x 50V 3.3µF 5mm, 12mm 2mm Y C331, C332,C333,C334,C167, CEA
UPW1H3R3MDD
C501(cant find this one)
2x 16V 10µF 5mm, 12mm 2mm Y C221,C156 CEA
UPW1E100MDD
1x 16V 22µF 6.5mm, 12mm 2.5mm Y C158 CEA
UPW1J220MED
4x 10V 100µF 8mm, 12mm 3.5mm Slight C209,C210,C313,C314 CEA
UPW1V101MPD
1x 35V 220µF 13mm, 24mm 5mm N C415 CEA
UPW1H221MPD6
2x 35V 47µF 10mm, 12.7mm 5mm N C311,C312 CEA
UPW2A470MPD
2x 6.3V 22µF 5mm, 12mm 2mm Y C309,C310 CEA
UPW1A220MDD
1x 25V 47µF 8mm, 14mm 3.5 mm Slight C502 CEA
UPW1J470MPD
1x 16V 330µF 13mm, 20mm 5mm N C133 CEA
UPW1J331MHD
2x 16V 220µF 10mm, 20mm 5mm N C131,143 CEA
UPW1H221MPD6
3x 50V 0.47µF 5.2mm, 12mm 2mm Y C150,C151 CEA film ?
ECQ-E2474JB
^1 extra not in schematic tacked onto selector
2x 35V 100µF 10mm, 20mm 5mm N C513,C514 CEA
UPW1J101MPD
CELL Marked
2x 25V 47µF 10mm, 13mm 5mm N C205,C206 CEANL
UKL1V101KPDANA
LR (low Leakage Caps)
2x 50V 0.47µF, 5.3mm, 14mm 1.8mm, 2.8mm Y C301,C302 CEANL film?
ECQ-E2474JB
2x 16V 10µF, 5.3mm, 14mm 1.8mm, 2.8mm Y C329, C330 CEANL
UKL1E100KDDANA
6x 50V 2.2µF, 5.3mm, 14mm 1.8mm, 2.8mm Y C203, C204,C211,C212,C511,C512 CEANL
UKL1H2R2KDDANA
2x 50V 1µF, 5.3mm, 14mm 1.8mm, 2.8mm Y C138,C141 CEANL film? ECQ-E2105JBB
2x 25V 4.7µF, 5.3mm, 14mm 1.8mm, 2.8mm Y C507,C508 CEANL
UKL1H4R7KDDANA
Polystyrene NOS Set of original replacements.
Resistors
4x Wire Wound Ceramic .22Ohm @ 2w 14mm long, 9mm lead spacing
Transistors (per MarkThe Fixer)
6x 2SC1919
KSC1845FTA
2x 2SA725
KSA992FBU
2x 2SA726
KSA992FBU
1x 2SD712
KSC2073TU
1x 2SC1284
KSC2690AYS
