Those poor souls who suffer my postings on AudioKarma(regard yourself as one of them....)will recall(suffer nightmares about even)my penchant for magnetic levitation of source components(after all the poor attempts at humour the mention of magnetic levitation has just turned-off thousands of potential readers...).
However,I am serious(well,as serious as I can be).
Due to the fact that my SAP(yes this is serious)Relaxa 3+ mag-lev platform cannot support the weight of my Yamaha GT 2000,I decided to drop a wad of cash(lots of cash)on 8(you read that right..8)Clearaudio Magix.
Just getting these things was a trial in itself(I won't bore you with the details.I will bore you though).It took nearly 5 monthsfor me to get them, from go to whoa(and there was lots of woe before I got to whoa).
I hate moving my GT 2000,because it's a friggin' heavy turntable.The promise of an improvement in performance on offer to an already amazing turntable, was the motivation which had me biting the bullet and doing the deed within half of an hour of getting these things home from the Post Office.
I was a little-bit disappointed upon spinning the first licorice pizza.It all sounded worse.Not gross,but distinctly bass light and not even up to the level of performance that I was accustomed-to hearing from this player.Recalling that when Audio Asylum poster 'Zog' was doing his 'Isolation Products Binge' and trialling the SAP Relaxa,that he found the breakthrough when he removed the fifth footer from the Relaxa.
In other words Zog found that the mag-lev footers needed to be loaded-down by the component to unlock the untapped potential of the stand.The only thing I had to-hand was a slab of marble which had served as the top plate of a Lazy-Susan.Thankfully this was able to slide under the GT 2000,because the Boston Audio Tune-Blocks which I use to support the '2000,elevate the '2000 sufficiently higher than the stock GT 2000 feet to enable the Lazy Susan marble to slide under it.
The initial impression of loading the Magix down was immediately positive.Now I was getting somewhere.:thmbsp:
Further experimentation has shown that where the marble item was exactly located underneath the turntable had it's own influence upon the perceived end-result.
I'm leaving the marble bit where it is for the moment,and I'll experiment a little more with some additional weight,just to see whether there may be more to be gained from loading the Magix down further still.
What I can say,is that if one has invested in a decent turntable I can recommend these(not cheap)footers for the contribution they make,because it is not subtle.
Some pics:
The first is just to show the Magix under the '2000.
The second is of the Boston Audio Tuneblocks SE(and Tuneplates).
The last photo is of the marble weight.
Some pics:
