Don't be. Haven't got it running yet.This is my jealous face.
Welcome to the SOTA club!!
Every once in a while I see the power supplies online . I think its a 24 volt AC but not 100% .
There is plenty of info on the official thread page. I am to at home but will see if I can get to my PS and make sure
which voltage it uses.
New covered are about 250 IIRC.
Nashou
So is that the original power cord, just needs a transformer?
Yes, no vacuum. Like what you did. Why Sota didn't do the plug that way to begin with.I'm still running the HP printer power brick mentioned in the thread that @Nashou66 cited to power my Sota. Has been working great for me.
@gary7 it looks like yours is not a vaccum model so all you need is a >28v DC power supply to the motor. IIRC, There should be a voltage regulator on the motor board if you have the Pabst motor that will knock the voltage down from the 31vdc of the HP supply ($17.00 on Amazon). You can see my hack on my thread https://audiokarma.org/forums/index.php?threads/sota-sapphire-basket-case-resto-project.662523/
After I loosen the 2 platter holding screws, can I lift off the platter to check the bearing? What grease should I go back with after cleaning & checking the bearing?I'm still running the HP printer power brick mentioned in the thread that @Nashou66 cited to power my Sota. Has been working great for me.
Keep the two platter lifting, Allen screws screwed in and snugged. Remove the jam nuts that are on them, leaving the platter lift screws screwed in for now. Then remove the center bolt - on a vacuum table it will have a small 90° elbow fitting screwed into the end of it. The elbow can be removed so a box-end wrench can more easily go over the center bolt, but you can remove the center bolt with an open-end if not too tight (you can, but need to be careful of the platter lifting Allen head studs you’re leaving there for now).After I loosen the 2 platter holding screws, can I lift off the platter to check the bearing? What grease should I go back with after cleaning & checking the bearing?
