Speaker Selector Switch Opinions
Discussion in 'Equipment Reviews & Opinions' started by Keneye, Feb 12, 2019.
  1. Keneye
    Keneye Member
    66
    York PA
    I have 2 receivers and want them to play nice with one set of speakers. But the speaker selector set ups I see are in the $75-100 range. Unless I am Missing something, all I want is a manual switch to select receiver one or two. Any suggestions for a simple cheap way to achieve that? I have seen "knife" switches as one option. Thoughts?
  2. 70's Rockfan
    70's Rockfan Active Member
    111
    Michigan
  3. 70's Rockfan
    111
    Michigan
    here's what the inside looks like.
  4. Keneye
    Keneye Member
    66
    York PA
    I only see one amp in. Want input for two amps.
  5. bbqjoe
    bbqjoe Void where Prohibited Subscriber
    633
    NW Arizona
  6. 70's Rockfan
    111
    Michigan
    OK , lets try it this way. since their are no electronic components
    inside this switch the terms in and out are meaningless.
    lets rename amp in as X.
    when you push button A it connects to X as does B or C
    connect the speakers to X and receiver 1 to A and receiver 2 to B
    Keneye likes this.
  7. bbqjoe
    633
    NW Arizona
    I've also heard nothing but awful speculation on doing this, due to possible amp damage if both are on, and the speaker load is dropped from one of them to the other.
    Or possibly back feeding an amp.
    I'm no stereoligist.
  8. lokerola
    lokerola AK Subscriber Subscriber
    1,999
    Alexandria, VA
  9. Keneye
    Keneye Member
    66
    York PA
    Thanks. Think I will just use receivers in rotation and manually switch. But I think 70s rockfan has the solution. Worth the few bucks to try it out. Stay tuned for any sparks.
  10. HTHMAN
    HTHMAN Super Member
    3,651
    St Louis, Missouri, USA
    A double-pole double-throw knife switch is the safest way. With some selector switches you can accidentally engage both leads with disastrous results. Make sure whatever you buy does not allow that. Most speaker switches allow you to use A+B
  11. TomBig58
    TomBig58 AK Subscriber Subscriber
    1,011
    Chicago
    They DO manufacture "break, then make" A/B switches to avoid accidentally sending signal from both amps but a homemade DPDT box isn't that hard to make. I've done it with a regular speaker box like post #3 but veeerryy carefully...ALWAYS!!
  12. don philipe
    don philipe AK Subscriber Subscriber
    1,143
    West plains mo
    I use one of these,
    Technolink TC-616 6-Way Stereo Amplifier / Speaker Comparator
    Reasonably priced and will do exactly what you want.
  13. HTHMAN
    HTHMAN Super Member
    3,651
  14. Keneye
    Keneye Member
    66
    York PA
    Once again, Thanks to everyone for the great suggestions.
  15. drtynes
    drtynes New Member
    7
    If you're looking for inexpensive, try some Speakon connectors (4 wire) male and female, will give you a quick disconnect
    from one receiver to another in seconds...
    Keneye likes this.
