repo_code
somewhere in the 20th c.
This recipe worked for me.
I have a lot of 44kHz audio (wavs, mp3s, songza) and a USB DAC that can handle 44kHz natively. So Linux should get this right, right? Nope:
john@dash80:~$ cat /proc/asound/card2/pcm0p/sub0/hw_params
access: MMAP_INTERLEAVED
format: S24_3LE
subformat: STD
channels: 2
rate: 48000 (48000/1)
period_size: 1103
buffer_size: 4410
That was while playing a 44.1kHz mp3.
Good news. If the recording is at sample rate X, and the sound hardware can handle sample rate X, we can avoid resampling. It just takes a little configuration kung fu. This recipe works on Ubuntu 13.10, using a QNKTC AB 1.2 USB DAC. YMMV.
By default Ubuntu's sound stack is: Your apps -> PulseAudio -> ALSA -> the driver -> hardware
PulseAudio is a software mixer, it allows multiple apps to play sounds at the same time. It may resample. ALSA may also resample, it has a built in software mixer called 'dmix'. You can disable both software mixers.
** Step 1 ** Disable PulseAudio by uncommenting the 'autospawn' line in /etc/pulse/client.conf and changing it to 'no':
autospawn = no
Kill pulseaudio with "killall pulseaudio" or by rebooting. Notice that it does not return; "ps -ef | grep pulse" won't find it again.
** Step 2 ** Create an .asoundrc file in your home directory. Here's mine:
# Avoid resampling. This is how:
# 1. Elsewhere, disable pulseaudio
# 2. Here in .asoundrc, create default pcm and ctl
# handles that don't use alsa's built-in 'dmix'
# software mixer.
# 3. Do use a "plug" wrapper around the underlying
# device. This can do lossless sample format
# adjustments, which lets way more apps work
# than without the "plug" wrapper.
# Q) How can you tell this is working?
# A) /proc/asound/card*/pcm0p/sub0/hw_params should show 44kHz
# when playing CD-quality mp3s or wavs.
# Create a pcm handle named "AB12", this
# maps to the underlying hw driver for the "AB12".
# Identify the card by name to avoid maintaining
# hardcoded numbers ("hw:2,0") that might change
# depending on what else is plugged into the PC.
# Your device has a different name, not AB12.
# Get the name from /proc/asound/card*/id
pcm.AB12 {
type hw
card "AB12"
# Bind a default ctl to the underlying hw driver
# for the "AB12".
ctl.!default {
type hw
card "AB12"
# Create a default pcm, use the "plug" wrapper
# to wrap the named PCM we created above.
# Plug will adjust sample format as needed; we can
# force it to never change the sample rate! Nice.
pcm.!default {
type plug
slave {
#pcm "hw:2,0"
pcm "AB12"
rate "unchanged"
** STEP 3 ** Configure apps to use ALSA rather than PulseAudio. This required a manual config change in Audacious. I told Audacious to use the "default" mixer and PCM devices -- the same ones defined in the .asoundrc file. Firefox didn't require any config changes, it seems to just use the default pcm and mixer.
Go play music, confirm that /proc/asound/cards/card*/pcm0p/sub0/hw_params matches the samplerate of the source material, and appreciate how much better it sounds
format: S24_3LE
subformat: STD
channels: 2
period_size: 1103
buffer_size: 4410
autospawn = no
# software mixer.
pcm.AB12 {
type hw
card "AB12"
# for the "AB12".
ctl.!default {
type hw
card "AB12"
pcm.!default {
type plug
slave {
#pcm "hw:2,0"
pcm "AB12"
rate "unchanged"
