Subs for batwing outputs 2SD587 & 2SB617?
Discussion in 'Solid State' started by slimecity, Feb 14, 2019 at 1:38 AM.
  1. slimecity
    slimecity Super Member
    3,240
    New Zealand
    Have a look at this amp - I may bid on it - looks like a challenge!
    https://www.trademe.co.nz/Browse/Listing.aspx?id=1944936412
    One set of outputs are fried. Modern equivalents? Is it worth getting this amp? It is well-regarded - just not sure if I will ever be able to fix that pegged meter......
    I also have two other "fixer uppers" at the moment to work on......
    I did find this thread which recommends mje15030 and mje15031. These seem like a lower power choice? Are these MJE types still the consensus?
    http://audiokarma.org/forums/index.php?threads/akai-aa1135-2sb617-2sd587-replacments.671136/
    Thanks!
  2. Oldsansui441
    1,886
    Victoria, Australia
    Hi slimecity, pity it wasn't just a case of the pre out/main in jumpers missing. If those batwing outputs are shorted l would personally just re drill the heatsinks to accept any TO-247 or TO-3P that matches the original specs as closely as possible.
    That meter may just have a build up of that white corrosion causing it to jam up. Might also be more major of course.
    Sorry l cannot comment on the NEC itself as have never even seen one before. It looks like it might be a dual mono design though, is this correct? Looks like it could be something interesting to me, also has a bit of an Akai look.
    slimecity likes this.
  3. slimecity
    3,240
    New Zealand
    Cheers oldsansui - yes it is dual mono and these amps are quite rare and well-regarded.
  4. Oldsansui441
    1,886
    Victoria, Australia
    Nice, l also learnt something today so thank you.
  5. Oldsansui441
    1,886
    Victoria, Australia
    Haha, l have just realised in your original post you said it "IS" well regarded, l read too quickly and thought you said is it well regarded, my mistake.
    Let us know if you decide to buy it slimecity :thumbsup:.
  6. Watthour
    Other possible replacement devices are FJP1943R/FJP5200 at 80W Pd in TO-220 cases, or the FJA4213/FJA4313 at 150W Pd in TO-3P cases.
  7. quaddriver
    quaddriver 120 What's per channel Subscriber
    I replaced cousins of these in a kenwood KR4070 - there is a thread on it in kenwood about a kenwood that went silent....
    BUT!
    I have similar D588, B618s here you can have (I have to retest them, been in a drawer for a while) but do not discount the FPJ subs...
  8. MCS Guy
    MCS Guy The MCS hoarder Subscriber
    598
    FL
    An MCS 3865 is the same amp if it helps. I would wait to get the unit before saying the outputs are bad.
  9. slimecity
    3,240
    New Zealand
    Cheers - yes I thought this too - it could be a misdiagnosis on the sellers part.
    Cheers all
  10. slimecity
    3,240
    New Zealand
    Thanks a lot for the offer Quad - if I win this auction I will test all outputs and I may be in touch!
  11. avionic
    avionic " Black Knights " Eagle Keeper Subscriber
    46,450
    Fort Dodge, Iowa
    Batwings... They don't even come close to resembling batwings.
    [​IMG] <--- batwings...:beerchug:
    I know, I know.. That is what they have been refereed to for a long time.
    Probably named by a person who has never seen a bat.:idea::dunno:
    thread crap over...
    Please continue gentlemen.....
    slimecity, redk9258 and dlucy like this.
  12. gort69
    gort69 AK Subscriber Subscriber
    1,163
    Vancouver, WA
    I used MJF15030G/15031G in a KA-5700 per EchoWars' recommendation in this thread. No live tab so no insulator required.
    rickl likes this.
  13. FootFungus
    FootFungus Super Member
    1,131
    Dallas
    If you want to go TO-220 I'd suggest the FJP1943/FJP5200's if you can get them. Otherwise the MJE15032/33 are quite a bit superior to the MJE15030/31s
    EDIT: Onsemi announced the discontinuation the FJP5200 (but not the FJP1943 yet...) so get them while you can. Also the R grade 2SC5200 is being canned (same die as the FJP5200).
  14. audiomaniac2
    audiomaniac2 Active Member
    123
    Modesto Cal.
    I had to replace some batwing transistors not to long ago. I took a screwdriver and pried the TO 220 transistor off the batwing heatsink and glued the new one on with JB weld. So far it seems to be dissipating the heat just fine.
  15. slimecity
    3,240
    New Zealand
    Thanks all.
    No further help needed as I didnt win the damn amplifier after all.
    I didnt see the need to pay over $150 NZD to get it - but someone else did.
    Stink one, and in the absolute shite condition it was in, too.
    I havent seen one of those come up for sale before in NZ, having said that
