This is a DIY project that has been on Audio Karma for about a year and has had a number of revisions, additions and upgrades. The original thread is c.110 pages long so it's time to do a re-boot.
High gain opamp based preamp for low output MC cartridges. | Audiokarma Home Audio Stereo Discussion Forums
The original thread has many test results and design philosophy/trade off discussions plus some construction experience and a lot of irrelevant chatter.
There are about 230 of the units in various versions out in the field. The design has been added to and revised several times and is now at v3.1.
As the title suggests, it is opamp based, and is hardly unique, but it has some unusual features, has stellar specs, and is pretty easy to build.
Some features:
1. Optional parallel input amps-
2x LT1115/AD797/OPA1611 or OPA1612 bipolar opamps for MC- extremely high S/N ratio for low output moving coil cartridges.
2x OPA1641 or similar or OPA1656/OPA1642 FET input opamps for MM- also providing extremely high S/N with high cartridge resistance/inductance.
Cartridge load components, both R and C, can be altered without soldering, allowing for loads from a few 10s of PF to uF.
2. 75us TC in input stage to optimize overload characteristic- approx. 28dB at rated -9dBv output at all frequencies up to greater than 50kHz with +/-15v supplies- an important feature matching high performance, commercial designs.
3. Additional standard RIAA TCs in output stage- again maintaining maximal overload margin.
4. Gain partitioning/opamp choices made to keep negative feedback factor high over the entire audio range to minimize high order harmonics and many tone IM distortion.
No visible degradation in noise floor at levels much larger than rated output due to IM even with many tone inputs, high order harmonic distortion (e.g 9th) below noise floor minimizing degradation of sound quality.
5. Inter stage TC added to compensate for the transition to unity gain of the input gain stage to maintain RIAA characteristic compliance. No unity gain transition in output stage due to choice of architecture. This contributes to the compliance with the standard RIAA characteristic.
6. Phase adjusted DC offset correction in the phono amplifier - so no coupling caps in series with the signal path and no LF peaking due to the correction loop.
7. Ultra Low distortion, high stability, high accuracy Polypropylene caps used in all of the signal paths.
8. Off the shelf SMPS used with custom designed input LC filter. >100dB of supply noise rejection at SMPS switching frequencies.
7. Extensive on board power supply decoupling.
8. MC and MM versions can be built with some component changes, with essentially qualitatively identical performance.
9. 62dB gain for standard MC stage, 42dB for MM. Nominal sensitivity- 250uv @1kHz, 5cm/sec for the MC, 2.5mv for the MM.
10. RIAA simulated compliance c. 20mdB p-p, 20Hz-20kHz. Measured with non selected off the shelf components to be <50mdB p-p. Simulated worst case <100mdB p-p.
11. Unmeasurably low (limited by measurement system) distortion at rated output, including harmonic and many tone. Also applies to line and warp filter sections.
12. Phono Warp first order "elliptic" filter with vertical (L-R) rejection of c. 3dB at 140Hz and c. 36dB at 2Hz. Nominally 0dB rejection of horizontal (L+R) rejection. Great for rejecting noise from warped records or for some rumble components without disturbing the actual music frequency response.
12. Additional 10dB gain can be selected in the warp filter section to increase overall gain to 72dB/52dB.
13. Ultra low distortion, low noise high dynamic range Buffers/amplifiers for volume control and line driving added, 47 ohm output impedance.
14. Mono switch and balance control functions available.
15. Optional balanced output drive, 47 ohms output impedance/side (excludes "14")
16. Optional (separate board) OPA1656/LMH6321 headphone amp. On board heatsinking. Can drive loads as low as 15 ohms. Unmeasurably low distortion for 30 ohms and higher loads. Output impedance c.0.1ohms. 6dB gain.
Can be powered using same SMPS as the preamp.
Measurement system. RME ADI-2 PRO FS R with REW.
High quality boards available. Schematics, measurement results, BOM and build guides available.
Mouser carts for the v2.0 boards.
https://www.dropbox.com/sh/3ax8p175lu2izoc/AADfl-SVvf84CR37Ra2lGMjla?dl=0
Pin strips for adapters
SMPS filter
RIAA MM single specific parts
RIAA MM parallel specific parts
RIAA MC single specific parts
RIAA MC parallel specific parts
RIAA Common parts
I/O parts
Line-buffer parts
Warp Main board parts
Balance control
Note: For the balance control, the 1.5k and 3.6K Rs replace R77/78 (9.1k) and R83/84 (5.11k) in the original line stage.
The balance board is assembled and wired between the Left mono and Right mono pads- left to left and right to right. Mono will still work, (i.e. a switch can short left mono to right mono) but it will disable the balance function if activated.
Headphone amp:
Headphone schematic.
Headphone wiring
https://www.dropbox.com/s/fu6nambryiqcots/HP-input-wiring.jpg?dl=0
The full schematic is too detailed to be visible except as a pdf.
v1.3 build notes.
https://www.dropbox.com/sh/r2rzhgtnb6b0m2t/AAAbOAk_lmSC9HwhT7G8KLiKa?dl=0
v2.0 build notes addendum
https://www.dropbox.com/sh/473t9jsaiv3jo1d/AAC6j1aOZU_10xlFV64ATMaPa?dl=0
V3.0, 3.1 full info, addendum.
https://www.dropbox.com/sh/92gig3oftxjqi9w/AACbKqpwnxBSPys9XDdVbqqSa?dl=0
https://www.dropbox.com/s/m62gn2j6ntb81hc/LOMC-v3-Addendum.pdf?dl=0
Some features:
SMPS filter
RIAA Common parts
I/O parts
Line-buffer parts
Balance control
Headphone amp:
Headphone wiring
v1.3 build notes.
