Im assumeing you've owned the ubove mentioned Dynaco's hence your opinion they don't meet "high end tube amps" list.How does Dynaco anything get into the high-end / Marantz 2 altitude?
Of course what I listen to daily
Fisher 50A mono amps
hhscott LK-150
Others owned
Heathkit w-4am
Heathkit w5m
Dynaco MKiv mono;s
Dynaco mk2/3 mono's
Others
All the early HHscott tube mono's
Fairchild
Eico mono's
Quad
Stromberg Carlson AP-55 mono's
there are others..
hunter
Harman-Kardon: Citation II, Citation IV
I'd put all of the Fisher stand-alone amps on that list.
I think you mean "Citation V." Someone at H/K came up with the clever numbering scheme where the preamp was one number lower than the amplifier in each line, but the upper and lower lines shared the tuner. I and IV were the preamps.
Audio Research: D150, D76a, Dual 51, D79
Conrad Johnson: Premier 1, MV75a-1, MV45a-1
Quicksilver: M135, MX190, 8417 Mono
Marantz: 9, 8B, 5, 2
McIntosh: MC30, MC225, MC240, MC60, MC275
Dynaco: Stereo 70, Stereo 35
Heathkit: UA2
I didn't take the time to mention the Others Sam
Fisher 30a
Fisher 55a
Fisher 50az
Fisher 80az
Fisher sa-1000
Fisher 200a
Special mention goes to the 50a/55a for their magical midrange sonics~!
hunter
hunter
Pilot SA-232 and SA- 260
Most Fisher tube amps
Bogen DS-265, DS-225
Heathkit: UA2[/QUOTE
Here is my list:
audio research D150
audio research D79 series of amps
audio research D250 series of amps
Conrad Johnson Premier 1
Conrad Johnson Premier 5
Mcintosh MC 275 series of amps
Dynaco ST70
Dynaco MK 3 mono blocks
Please fellow members add more
930
Btw I forgot to mention the audio research D50 . This amp is the favorite vintage amp of the Warren Gehl the person responsible for voicing almost all of the electronics past & present of audio research .
I would agree on fit/ finish for sure not being up to Marantz 2 territory,but sound wise they are NO slackers.My tech buddy and I have been buying/rebuilding these pieces for some time ,Robust power/output trany's,recapped with quality caps/nos tubes, paired with good quality vintage tube preamps will shock a lot of people.
How can I forget the Marantz 9 & 8,2 and of course the HK Citation 2 the 1st tube amp auditioned in our system w/c prompted us to buy our 1st tube amp the audio research D79B.
Well considering At the time of design, then production David Hafler"s {formerly of Accrosound...excellent trafo's}Dynaco Amps were considered the"poor mans McIntosh"
and his early MKii/MKiii/MKiv mono's gathered a huge following as is apparent by the numbers sold and available to this day.I very seldom happen upon a dynaco tube product that still to this day doesn't sport its original OPT's or Trafo's after all these yrs, a testimony to their build quality!Were there some penny pinching in Haflers products of the day..im sure...but his Ultralinear circuitry incorporated in his amps and Trafo's were well respected. He both sold Kits and factory assembled Amps to the audiophile mass's and made hi-end sound available at a lower price point.
If you consider the Hafler designed tube products "second rate" id say that's not bad!!!In my experience In a blind test against period matching tube mono blocks from Mac and Dynaco all things being equal wpc/preamp/speakers/and source your ears or mine would have a hard time decerning the difference,there are tube amps that measured "better " in square wave/bandwidth exc ...sure,doesnt always mean the product is inferior when considering end "sound".
All in all if meeting Hi end tube amp criteria is amps that produce a richness of tone,sweetness across the audio spectram then yes in my opinion Dynaco can be included on this list.
hunter
