theprep
Member
I recently picked up an old solid state Motorola console radio that appears to be from the late 60's/early 70's. Overall in good shape but has a few issues that come with age.
The volume was previously scratchy, you had to get the volume level just right for the left/right channels to be of equal volume. This seems to have worked itself out with use.
The turntable needs greasing, at first it took the deck a while to get up to speed. The main issue now is the tonearm seems to have a short. At times, it doesn't even play sound to the amp though you can hear the pickup playing.
Needle stays in groove, the issue now seems to be the connection in the tonearm. Audio drops in and out, I can tap the platter to get it back, but it moves either to the left or right channel, most times the left.
Very rarely does it play out both channels, so I am guessing it's the connection in the tonearm itself?
It also has a very low hum, especially noticeable when "Tape" is engaged, as I use a cable to play Spotify from my phone.
I assume the whole board needs a good spray as wells as the RCA jacks, and pots?
My only plans are to replace the speakers with some decent Parts Express (Vifa or the like)
I realize it's not hifi, it's more for functional nostalgic decore, it was only $24
