What amp drives your Infinities?
Discussion in 'Infinity Loudspeakers' started by caddisgeek, Mar 8, 2010.
  1. caddisgeek
    caddisgeek sorry.......what?
    2,766
    Southwest Vic, Australia
    Hi All, Just wondering, what does everyone here drive their Infinities with?
  2. inkman69
    inkman69 Active Member
    295
    Kansas City Mo.
    I have the Kappa8s and I use a single Pioneer Spec2 amp. I will be adding a second Spec2 to biamp the Kappa8s soon.
  3. thevic24
    thevic24 deep in sound thought
    653
    Columbus Ga
    I have a few amps that I use in a rotation of sorts.
    Right now, Iam using a Bob Latino ST120 with a VTA driver board and EH6550 output tubes.
    Its rated at 60wpc and it drives my Kappa 6.1's 10 times better than the Adcom GFA 545II that it replaced.
    Sometimes I run them bi-amped with an Adcom GFA555II on the bass and a Carver TFM 15CB on the upper end. This is a really good sounding combo but IMO the ST120(tubes) do much, much better.
    -Vic
  4. rabbit
    rabbit Well-Known Member
    652
  5. mbeigh
    mbeigh AK Subscriber Subscriber
    266
    Zionsville, IN
    RSIIIa with an Adcom GFA-555.
  6. Maxamillion
    Maxamillion Super Member
    1,346
    New Jersey, USA
    For my RSIIb speakers I use Gilmore Raptor monoblocks (500wpc into 4 ohms, 250wpc into 8 ohms). They have no coupling capacitors, a massive linear power supply and weigh 37 lbs each, quite heavy for a class D monoblock. I find them very powerful but also musical, without the high-end glare sometimes associated with class D amps.
    http://www.glacieraudio.com/new Gla.../Gilmore/Gilmore-amps.htm#Anchor-Raptor-11481
  7. 240sx4u
    240sx4u Lunatic Member
    10,817
    Madison, WI
    Pse studio IV monoblocks. 160wpc @ 4 ohm and incredibly stable.
  8. Augy
    Augy Well-Known Member
    715
    Northeast usa
    I have 2 sets of kappa 9's ...... I use a Sunfire Series two on the woofers 325wpc @ 8 ohms which can double down to 1 ohm and a Nakamichi PA-7 on the mids and highs. On my second system I use a sae 2401 on the woofers and again a Nak PA-7 on the mids and highs... The Sunfire definatly has more punch than others I have tried and the NAKS sound real nice on the top end....
  9. NumbDiver
    NumbDiver Super Member
    Bi-amp'd IRS Gammas:
    Mesa Baron tubes up top
    Bryston 4BST on the lows
  10. racerxnet
    racerxnet New Member
    15
    4 - 7BSST's on the RS1B's
    2 33H's on the Genesis 200's :D
  11. ugornot
    ugornot Poly Woofer?
    478
    Adcom 555 -rsIIIb
    NAD 2600 RS4B
    HK 3480 RS5B
    Carver 900 RS5B
  12. t40killa
    t40killa Well-Known Member
    507
    Yamaha M-2 for the RS II
    Yamaha M-85 for the RS IIIb
    stevo137 likes this.
  13. siramazing
    siramazing AK Member
    253
    Everett, Wa
    RS-1b's..currently using Krell KSA -250 on top (have also used VTL MB450's) and two Bryston 4b's running mono on the bottom.
  14. junkaudio
    junkaudio Super Member
    infinity kappa 9 biamp with mcintosh mc 2100 in mono for bass ,midrange vtl stereo 90 or sometimes audio research classic 60 (8 6550 in triode ) :music:
  15. kmanusa
    kmanusa Well-Known Member
    602
    Northern Virginia
    RS-4.5 speakers driven by Sunfire 300, (2) Bryston 4B-ST, Mcintosh MC275 IV, MC2205, MC7270. Amps used in combination when biamping or by themselves full range (I only use the MC-275 on top when biamping).
  16. nailzgun
    nailzgun Infinity - Threshold nut
    168
    Burlington Ontario
    I drive my Ren 90's with a Threshold 400A.
    My Kappa 9s which are my primary speakers are currently driven with a pair of Threshold S/500 IIs. I am awaiting arrival of a second Threshold SA/2 which I will have rebuilt and then the pair will be driving the high pass on the 9s with one of the S/500s on the low pass and the other moving to the Ren 90s.
    I will then move the 400A to my Kappa 7s.
  17. Jonesy09
    Jonesy09 Super Member
    1,381
    Fitchburg, WI
    RSII's have a Carver PM-600 right now. These will soon be bi-camp capable so I grabbed a Carver m0.5t for the mids & tweets. After I get a tube pre on these things I'll likely change it up.
  18. kurtgo
    kurtgo AK Subscriber Subscriber
    930
    Piper, KS.
    Parasound 3500's on the 4.5's - vertical biamp (500 watts per/4 Ohm, 120 amp, >1,000 damping factor!)
    Parasound 2205AT powering the 4 other 2.5's.
    Carver TFM-45 on the Kappa 6's.
    Yamaha receiver on the Kappa 7.1 Series II's.
  19. kcollins4
    kcollins4 Rocking somewhere
    5,730
    Katy, TX
    Yamaha CA-810 driving 2500's.
  20. Ken Boyd
    Ken Boyd AK Subscriber Subscriber
    16,910
    Florida
    Several Racks that I rotate around, one all SAE, preamp, parametric EQ, CD, tuner, active crossover, speaker selector, and a pair of 2400L, set up to for bi-amping.
    Another Rack of all Phase Linear series II, Preamp, Tuner, Parametric EQ, Spectrum Anyalizer, Time Delay, Noise Reduction and Range expander, and three amps, one 300 series II, a 400 series II, and a 700 series II.
    A couple of other racks with assorted equipment from Crown, Mcintosh, Sansui, SAE, Rane, DBX, Soundcraftsman, Infinity electronic controllers for the RS-1, and RS-1b's, Denon TT, Tascam cd and cassette. Plan on in the future to refine these out and make them into one Mcintosh rack, and one either Conrad Johnson, or Audio Research rack, tubes for the mid-highs, and SS mono blocks for the base towers my RS-1, and RS-1b's.
