It means it splits the signal into positive and negative going halves, when that isn't done, the transistor on the opposite side of the push pull output driver for that polarity is inadvertently "switched off" by the waveform, and when the driving side / polarity is swapped (audio signals swing positive and then negative) and that transistor is supposed to be ON already, it takes time to "wake it up", causing some distortion.
