currituckco
Anyone have any experience with these? I'm building a preamp (see thread: http://www.audiokarma.org/forums/showthread.php?t=155393) that uses a pair of these in parallel and I haven't been able to get them to light up even. They light up in my tester but not in the circuit.
Does anyone know what input voltage they require to light up? The schematic puts 300VDC on the input, but that also confuses me because 300vdc is the supposed output as well - don't regulator often need a higher supply voltage than their output will be? Also I found this:
http://members.aol.com/sbench/reg5.html
Their parallel example is an 0A2 and an 0B2, producing 265v regulated. Their supply voltage I think is much higher, if I'm doing my Ohm's law right:
"Since the power source produces about 490 volts when loaded with 20 or so mA, I'll use a 10k resistor to drop the voltage to the 2 series VR tubes, passing slightly more than 20mA thru the tubes."
I took this to mean .020A x 10kR = 200v, which would be the voltage drop on the resistor...so 290v supply voltage. Is this correct?
I can't figure out what's wrong in my circuit...Schematic in the other thread and details of my problem...
I guess my question here is, what does it take to get these things to light up? Is it a certain input voltage? Is it something else?
