Any adapters at the base that you could use to maintain the original diameter of the pins ( ?? Magnoval )........Thanks...
Thanks for that information Dave. Does Jim McShane sell NOS or good used matched quads? I'll guess they're expensive, but I would be willing to consider it.If I may -- actually, you need both figures, but as you found out, one figure is no guarantee of the other. Having matched cathode current draw under quiescent current conditions is important to minimize output transformer saturation at low frequencies, and keep output tube dissipation levels in check between all four tubes. Tubes that are balanced under this condition have a good "static" balance. However, a good "dynamic" balance is just as important to minimize distortion produced in the push-pull connection. So you need both -- a good static balance which is based on the DC characteristics of a tube, and a good dynamic balance, which is based on the AC characteristics of a tube. A Gm test (the transconductance test aeyb701 mentioned) is an AC based test to aid in dynamically matching tubes.
However, as I mentioned, just because a pair of tubes has a good static balance is no guarantee that they have a good dynamic balance -- and visa versa. Good dynamic balance is no guarantee of good static balance. The better tube vendors like Jim McShane match tubes based on both criteria -- and do so at real world operating voltages. Therefore, tubes purchased from him will have both good static and dynamic balance to produce the lowest overall distortion at all frequencies and power levels. No affiliation -- just a long term satisfied customer.
Dave
There again is a case for individual output tube bias, such as Dave's bias-balance mod.I've never seen one. I have seen 7868 to 7591 adapters, but I don't know if those have the skinny pins. 7591 tubes seem to be less available in old stock anyway.
As for the terrible match on some old stock, I have to agree on that. I've got an NOS set of Sylvania that are just all over the map. Distortion performance is worse than it ought to be and it requires all of the adjustment range I can give them to get the idle currents to line up. I actually had to go back in and fiddle with the values on the bias adjustment board to get enough range to make it all go. To be fair though, the tubes were not sold as matched or tested in any way, it was simply sold as 4 tubes with the same markings and that is indeed what I got.
That's a novel solution, though I think it would take a while. Dremel grinder? Just be careful of not going too far, weakening the pins or worse, like marring the integrity of the glass or plastic base. Nail file would at least offer greater control.Just a thought ,can you use a nail file to decrease the tube pin diameter ???
See rudpra? Always something to learn on AK. Never have thunk it.You would destroy the plating and it could lead to corrosion - not a good idea IMO
