accuphase P300 d16 diode
dave collins
On board 720 protection I found a T 18 diode in place of the diode in the parts list which is a rectifier diode 1S2091 BL. My lights are flashing and the voltage going to the relay is the same on the positive and neg terminals so the relay won't close . Should I use the zener or the rectifier at D16? The schematic says rectifier.
D16 is the flyback diode, protects Q8 from the pulse of the relay coil collapsing. It's just a regular diode, 1N400x is fine.
