So I have a crown CDI 1000 that I have been using to power my DVC sub. It has been working well. I have each channel powering the separate voice coils so its running 2ohms per channel.
I now have a QSC RMX 1450 amp to try.
Both amps are rated for 700 watt per channel into 2ohms at 1% thd. The crown is a class D amp. The QSC is class a/b.
Just curious if anyone thinks which amp would be better. I'll need to open and clean the QSC then test on some cheap speakers to make sure its good to go. Its quite dirty at the moment.
Just sparking a small conversation. I know "just try it and let us know what you think". Anyone by chance used the QSC for sub duty?
Thanks
Justin
Thanks
Justin
