Denon 5 CDP belt needed
outlawmws
On the Run
Where can I get a belt for a Denon DCM350 5 disk changer? This belt moves the platter transport and was slipping so bad it wouldn't work without a nudge. Hard to do when closed...
We replaced it with a rubber band and got it working, :D but I expect that to rot away inside of a year. As big a pain as it was to get to the belt, I only want to do it once more. (actually I don't even want to do it once more, but that rubber band... :no: )
You might check this site-
http://www.kenselectronics.com/lists/belts.htm
I have a .doc file with a link to the place I got a VCR belt from, but it won't open with XP and MS Works, dangit. So, I'm not sure if this is the place I ordered from, or not. All I know for sure is that I measured my old one, found a match, and it worked.
