waveydavey
Help Please With Dodgy Anti-skate on AT1100 Tonearm??
Hi all,
have recently received an Audio Technica AT1100 tonearm out of Japan. While setting it up on my tt I noticed from about 2" in from the outer edge of the platter to the spindle the tonearm is pushing toward the outside as if the anti-skate is on. In the area outside this the tonearm floats without moving.
On close inspection I have found the anti-skate spring seems to be taking up at this position, can't actually see the spring but there is a fine wire which i can see tensioning between the anti skate adjust and mounting shaft.
I would appreciate any assistance or remedies you may have.
Cheers, Dave.
Hi all,
Cheers, Dave.
