Kill HD Radio Now, While It's Still on Life-Support!
mts7471 said:
I noticed the other day that scanning on a digital tuner that it stopped one channel above every station that broadcasts in HD radio. Example, a radio station at 97.1 would cause the scanning to stop at both 97.1(actual station) and 97.3(loud static), but not at 96.9. I noticed this on about 6 stations in the area that I heard are broadcasting in HD radio, the other stations that don't broadcast in HD didn't cause this problem. Has anyone else noticed this or heard about problems like this? I'm thinking the side carrier for the HD broadcast is causing the tuner to stop on the adjacent channel. I'm wondering if anyone else has any thoughts on this.
Thanks
- Mike
There has been extensive discussion of this in the Yahoo FM Tuner Group. You can get to them via their home page at
www.fmtunerinfo.com
Most people in the FM Tuner Group are vehemently opposed to HD Radio because it (a) HD Radio sounds terrible (it utilizes a lossy codec running at about 96Kbs), even worse than MP3; and (b) Most HD Radio installations end up causing the exact problems you have described.
To briefly rehash what's been learned:
(1) Go to
http://users.tns.net/~bb/hdrsn.htm for a technical explanation and graph of what you are now experiencing with HD Radio.
(2) Most stations don't engineer the HD Radio install properly and their signal ends up "bleeding" over into the adjacents on either side. Sometimes it affects one side more than the other. So a station at 97.1 could make stations at 96.9 and 97.3 virtually unlistenable.
(3) There have been a
handful HD Radio stations that have done a proper engineering installation and these seem to be only the HD Radio stations in the Chicago area according to one of the posters in the FM Tuner Group. It is expensive and time-consuming to install the HD Radio broadcasting equipment so that it does
NOT affect the adjacent channels.
This is likely due to most FM stations firing their own station engineers years ago and contracting out their engineering needs to just a once-a-week visit.
(4) There are some tuners that are immune to HD Radio adjacent channel interference and some of them have been discussed in postings in the FM Tuner Group as well as in the site URL in (1) above.
(5) The potential for this interference problem with HD Radio was raised with the FCC during the licensing process HD Radio went through at the FCC, but the FCC chose to ignore it.
I don't know the politics driving HD Radio, but I can say that Congress, while continuing to slash the budget allocated to the Corporation for Public Broadcasting managed to find and allocate funding that would permit
ANY public radio to add HD Radio to their existing station and
not pay a penny for the equipment - Congress managed to find funds to pay for any HD Radio equipment a public radio station wanted to install.
I will leave you to speculate on the political implications of this. :scratch2:
(6) Because so many stations have done such a poor job of installing their HD Radio equipment, Ibiquity Corporation, the inventor and owner of HD Radio, has now petitioned the FCC to allow them to change the HD Radio specs, that, if approved by the FCC, would result in even
MORE interference with the adjacent channels.
(7) Some urban stations whose Arbitron ratings are being hurt by suburban stations adjacent to them are
purposely letting their HD Radio station bleed over into their competitor's spectrum in an effort to cause their competitor to lose listeners. No station will of course admit to this practice, but it has been discussed at length in the Radio Industry's professional trade journals.
(8) IMHO, the best thing you can do if you are affected by this problem is to file a formal complaint with the FCC reporting the station causing the problem. Click on this URL to file a complaint with the FCC:
http://tinyurl.com/fpg3z
Be sure to copy the offending station on their complaint. Anytime a listener files a complaint about a broadcaster with the FCC it becomes a big deal, particularly if the complaint involves poor engineering by the FM station. The FCC keeps a list of all complaints filed against all Radio and TV stations and the stations must periodically renew their broadcast licenses with the FCC.
Complaints can become a deal-breaker, particularly if another business group is trying to gain control of the frequency that is up for renewal, so most radio stations are
very sensitive to having a listener go to the trouble of actually filing a formal complaint with the FCC.
And if you feel the offending station is purposely trying to "jam" a competitor on an adjacent channel, be sure to mention this as well in your complaint.
HD Radio is still in its infancy and will be on life-support for at least 2 or 3 years as there are no radios to buy. Most stations that implement HD Radio
don't even have a monitor to listen to and monitor their HD Radio broadcasts! If every FM station that converts to HD Radio gets 50 to 100 (or more) complaints filed against them, this
WILL BE NOTICED at the FCC and it would be a big help in killing off HD Radio.
