So, do I further apply the updates (comments/ observation from #7-9) to my boards which already have the soldered together 12 mH, 330 ohm, 1uf capacitors to the one 2.7k resistor?
I am curious of the serial number. Have been tracking these.That is a factory modification to the first production boards. The later boards had incorporated tha same changes neatly on the boards. On the schematic I believe the components are reflected in the schematic. Should not need to modify either configuration unless the components are bad.
E02. Ends with SU. 1689 sandwiched in between
Here is a picture of the component side of the two versions of the left channel sub circuit board. The top picture shows the original board with the modification that added the four additional components. The bottom picture shows the updated version of the board with the four components in designated locations.
I'm currently updating the left channel sub circuit board modification on my board with new components. The schematic here is not in the same order as the original setup or pictures. The original setup and pictures here goes like this: one side of 2.7k resistor to 12mH inductor to 330 ohm resistor to negative side of the 1uf capacitor positive side of 1uf capacitor to other side of 2.7k resistor. The schematic displayed here goes like this: negative side of 1uf capacitor to 2.7k resistor, positive side of 1uf capacitor to 12mH inductor to 330 ohm resistor to other side of 2.7k ohm resistor. Which one is it?
