The faceplate comes off as an assembly. Remove the inspection cover (on the top) and bottom cover and you will find the screws that attach the faceplate assembly to the chassis. Remove those, and all of the knobs and one can carefully slide the faceplate off. From there, it needs to be disassembled (remove the end caps first) so that one can remove and replace the glass.
