HiI have been beating on the Mach one to loosen them up from a long time sitting.. cant say yet if the polk tweeters are more, or less or equal with the Mach tweeters but boy you need to hear them, clean clean clean, its so fun when you discover a little gem when you don't expect it. I see two used Mac one tweeters in my future to keep in my Arsenal.
I can say I don’t have the power to test the 260 watt claim but I do know they will gobble up 100 watts without any issues and the woofer at that lever will pump out what you want to hear without any stress and do it quite well. I have run them for extended periods with the port plugged with a sock and open. There is some difference but not a ton. Again open or closed it’s all about what you want to hear. I still play with both ways after having them for years and still haven’t figured out what I like better. There is a difference but it’s not huge enough to pick one after all these years.
I have a Gen-2 Set Liquid Cooled Mach One's I purchased New in 1983...I have been beating on the Mach one to loosen them up from a long time sitting.. cant say yet if the polk tweeters are more, or less or equal with the Mach tweeters but boy you need to hear them, clean clean clean, its so fun when you discover a little gem when you don't expect it. I see two used Mac one tweeters in my future to keep in my Arsenal.
There are a few threads on the Mach one by someone called video lady I think it was that was doing upgrades and testing the results. It’s an extensive thread. Should be able to find it easy by maybe searching Mach I upgrades.I have a Gen-2 Set Liquid Cooled Mach One's I purchased New in 1983...
I thought I read somewhere that the Tweeters & Mid-ranges need work being rebuilt...
Are you familiar with the procedure ?
