Hi all.
I wanted to post about my first tube amp and some issues I discovered reading online after I purchased it. This is a made in China, off Amazon, Nobsound 6P1, which has a major design flaw: the first cap after the rectifier tube being 150uf. This severely overworks the rectifier tube, causing them to fail and also possible arc if short cycled before this cap has drained down, which could take a while.
I swapped out that one cap for a 22uf 450v I had on hand, but plan to go down to a 4.7uf when I open it back up and see if it's still quiet. The tube sheet specs 5uf, but I don't think 22uf is going to kill it. The 150uf sure will! Mine came with a Soviet 5Ц4С slow rise rectifier, some came with a 5Z4, both have a 2a heater. I have no idea what the transformer is rated for on the 5V heater so be careful swapping tubes here.
The other issue, for use in the US, is a 110 mains tap which makes everything over-volt. I see in the Amazon reviews people saying they quit working after a few months and I have to believe this, along with the super oversized rectifier cap, is probably why. I put a 12.5V 3a transformer in a bucking configuration inline to resolve this voltage issue. The power trans also runs much cooler now.
I later changed the Chinese output tubes for 2 matched pairs of Soviet 6p1 tubes (install the matched pair in each strapped channel) and played with different 6SN7 tubes until I found a pair of driver tubes I liked, as the make/model of driver tubes make a big change in sound in this amp. Honestly the installed tubes sound pretty decent but I did find a pair of 6SN7, some old short bottle, side getter GEs, that helped the bass some.
I ordered a pair of 15w Edcor 3.5K OT with UL taps and plan some further mods like a bleeder resistor for the PS caps and separate bias resistors/caps for each output tube. I want to play with ultra linear mode and possibly some schade style feedback.
At this price point, for a real point to point wired tube amp, it's been a sweet sounding introduction into tube HiFi. I'm gathering parts to build one of Kegger's designs next, a KT88 amp he posted here:
https://www.audiokarma.org/forums/i...ct-single-ended-amp-seul.382162/#post-4823025
I do believe these kinds of home brew mods are just part of the deal with these made in China tube amps. It reminds me of shooting with Soviet era medium format Kiev cameras back in the 1990's. You could either pay $$$$ for a Hasselblad/Mamiya, or deal with upgrading/modifying the Soviet copies to make them usable.
