Nikkotopia
I was gifted a 771 by a friend a couple of days ago. He said there were a couple of problems with it, sound cut-out when moving some of the pots maybe a couple of other issues. He had moved on to other equipment and was hoping it would find a good home. I told him I would be happy to take it on! He also gave me the original Owners Manual, Service Center Listing and Circuit Diagram, so I'm pretty sure he was the original owner, and it is very clean and undamaged. I have given it a test drive and it sounds great with my iPhone steaming jazz stations into some Infinity RS-8a's, so I'm really happy with that! It did cut-out a little turning the balance pot and the volume pot was a little scratchy. A couple of the tuner dial bulbs are out and there is nothing from FM or AM, or the Signal Strength meter. For starters I just want to clean the pots and switches and see if that helps anything else. I have and have used De-Oxit before and know to just spray the pots and switches and not get it all over the place. I removed the wood case and bottom cover but the switches and pots are all above the Tone Board and below the Tuner Board. What is the best way to get at the pots and switches so that I don't take apart anything I don't need to, and do the pots have an access hole to spray into, or is some disassembly needed?
Giving it a general look over with the covers off, there is just very light dust and no sign of scorched boards, parts or bulging caps.
