Sony STR 7045 question
dloosemo
AK Subscriber
Hey everyone,
First post in a long time but with all the time off with the covid stuff I've gotten back into the vintage stereo game with a vengence. Anyways I have recently added a Sony 7045 to my main listening system and absolutely love its sound. Wasn't expecting it to dethrone the Marantz 2245 but it has by a long shot at least to me. First thing I did before hooking up the Sony was to check the dc offset, 14 mv and even on both channels not bad for an un restored unit. Next I checked the bias which was reading at 48 mv on both channels, as per the manual the bias should be at 50 mv and offset of course 0 mv. I didn't do anything with the bias as i figured it was close enough to 50 mv that adjustment wasn't warranted or a good idea since it was so close. I did adjust the offset to 0 and it is holding that setting with no problem after a week of use. So what my question is I was wondering how warm your 7045 or 6055 6050 run. I notice that after around a half hour at idle with no input the heat sink is starting to generate a very small amount of heat, just enough to tell that there is tempreture there above cold unit off conditions. After running the unit at high moderate volume levels for a few hours the heat sink is on the upper end of warm to the touch, not hot or burning but definitely warm flirting with what i think might be excessive? Unit has room to breathe and speakers are Phase Tech 3t bookshelfs with 90 db efficiency and an 8 ohm rating so not a hard to drive speaker. At any rate just wondering if this is normal for this receiver or if its the sign of a looming problem, like i said the unit does sound great though. Any thoughts/suggestions are appreciated.
Sorry for the long winded post,
Thanks
Dan
Kick back relax and enjoy. Take two adult beverages and call back when the infrared thermometer starts to read above 140°F.
maximum operating temp of the inside of the power transistors is about 250°C and with heat sinking sucking that heat away, 140 is a conservative number for it is starting to warm up.
Thanks for the reassurances and thats exactly what I did :) I can hold my hand on the heat sink as long as i want when its at its hottest so we are not talking insanely hot but was just curious since this does run noticeably warmer than the Onkyo 7055 it replaced which does have a much larger heat sink so thats probably the reason. Anyways back to a beverage and some tunes.
Thanks again
@dloosemo Hey Dan, I am new here so not sure if this is the best place to ask this question, but above you mentioned checking the DC offset and bias on your STR 7045. I may be acquiring one and while I have a reasonable basic background in electronics, I have never worked on a receiver. Might you be willing to provide me some guidance on doing the same, or perhaps pointing me in the right direction to find this information?
Thanks, Rob in Atlanta
1) find the Service Manual.
Since Hifiengine and vinylengine are no longer taking new members manuals are harder to find but may still be available for the full price an aker is usually willing to spend, $0.00. There are other ways to get them but the bias and offset information for each particular unit are usually detailed in the service manual. If you have worked on electronics having the sm for stereo gear should explain what you need. If not, start a thread about what you are doing in the Solid State forum and folks will help you out.
Get a pair of minigrabbers for your voltmeter before you slip a probe off the intended test point and short out the unit, making it need repair. Everyone has done it you will too so get some miningrabbers for your meter.
dloosemo,
The STR-7045 is a great unit, listening to it now. FYI, It is essentially the same unit as the previous STR-6055. I’ve been using it for a couple years, all original and it presents beautifully. Eventually a recap is in order.
AK has a database and you’re in luck, someone has posted the Service Manual for this unit:
Database:
https://audiokarma.org/forums/index.php?threads/here-is-the-database.434490/
STR-7045:
http://akdatabase.com/AKview/displayimage.php?album=search&cat=0&pos=0
also as a bonus, Sony manuals from this era are very well written. A joy to read with a cup of coffee in the morning as the sun comes up.
…as Blue Shadow noted if you have questions start a new post in this forum, and consider building a dim bulb tester. Enjoy!
I have 2 STR-7055's, the next one up the line. They look good and sound great. I have a theory about Sony stuff, the people who bought it tended to be older and more conservative but wanted good sounding stereo equipment. I find that most of the Sony equipment is in better shape the the others of the same age. I also have an STR-V4. Always on the lookout for Sony equipment.
