Teej
I inherited my Dad's old Technics SL-D3 fully automatic, and it's been running like a champ for a few weeks now; but I suddenly have a mechanical problem I don't know how to fix.
The other night I hit the "Start-Stop" button. Usually this prompts the platter to spin and the tonearm to lift and cue itself over to the correct position (as indicated by the record size switch which is pretty much always at 12") and lower onto the record. Like I said - this has been functioning perfectly in the weeks since I got it.
The other night and every night since then, when I push the start button everything happens as normal, but after the tonearm cues itself over to the correct position, it appears to snap itself about two inches further (roughly around the correct position for a 10" record), then lower onto the record. As 95% of the records I play are 12", it now always starts almost in the middle of the record side. This is despite the fact that the record size switch is in the correct 12" position.
I can still manually cue the tonearm up, move it to the correct position, then lower it myself manually - I already do it this way on my Technics SL-Q202 and I don't mind. It still plays like a champ and sounds great. But the "Start-Stop" was so cool and easy, and I miss it working correctly.
I am not mechanically inclined, but if someone knows a fix for this that wouldn't involve me destroying this beautiful table, I'd like to give it a whirl.
Thank you!
Thank you!
