schoenradt
New Member
I am having a terrible time trying to keep the left output transistors from blowing. I have replaced the output transistors and upgraded all the 1/2 watt resistors to 1 watt resistors. Unit states it supports a 4 ohm load. I have checked the bias and all the transistors ahead of the final outputs. Unit ran fine for several days using 8 ohm load at about 25 watts per channel. When performing a load test using 4 ohm dummy loads volume was set to level 4 and unit was consuming about 2-1/2 amps on the AC line. Test ran about 15 minutes and poof. I also noticed the left output sounded weak in low frequency response, but no clipping under a level 5 setting.
Any suggestions on getting the left output to work correctly? I have never had an issue repairing a receiver until this nightmare came along. Some of the history was this unit has been into Muse Audio several times for servicing. The work looks good and they did replace most of the electrolytic capacitors in the power supply, main output amplifier, and preamp/tone boards.
Just an update. I believe the problem is self explanatory.Since this repair has always blown the left channel output transistors and the right has remained operational it can only mean one factor. The replacement Sanken output transistors are counterfeit and will not comply to the OEM specifications. I am going to use substitute the BJT's and modify the heat sink so they will mount the same as the originals. I have found some OnSemi and SK transistors that should work.
So it looks as I found some substitute transistors for the output. They are as follows NPN FJL4315OTU and PNP 2SA1943OTU. I will have to revise the heat sink and center the new package outline for a TO264-3. The replacements are rated at 17 Amp IC, and 250 VCE. So they should work.
