Recently got a better faceplate for a 9090db and the one I'm taking off has some scratches and a couple small gouges. The gouges are in the area of the black lettering so that will be left alone. I'm going to sand out the scratches as they are not near the black lettering and was wondering if anyone has done this successfully. I have sanded out scratches on aluminum and SS before with fine grit wet/dry paper and polished to completion with success but, the 9090 faceplate has what appears to be either a satin brushed finish or sanded finish. Has anyone replicated this finish and if so what did you use.....a fine grit flap disc or maybe a satin finish wheel (fine or med texture).
I have put satin finishes on other metals before but the striations do appear to be the same as on the 9090 faceplate. I would like to match the existing finish as close as possible.
Thanks for any input or ideas.
