Bought HomerJSimpson's extra 2325 a bit ago and am just now trying to get it tuned up. It has a number of issues, including a non-OEM relay, burnt indicator lights, burnt fuse lights, and a really beat up wood case.
Some questions:
1) The $#!%$#@ fuse light plastic holder is melted to some degree. Despite getting the indicator light bar off and all the screws off the fuse light holder, (two up top with the plastic U connectors, and two on the back of the light bar) I can't get the light bar to come out. Am I going to need to carefully chisel melted plastic out until the bar comes out???:grumpy:
2) there's been differing info on the specs for the stereo indicator bulb. Some folks think it's a 12V 30mA, and others think it's a 8V 40 mA. The bulb that's currently in there is a 8V 40mA, along with all the rest of the indicator lights. What is the correct value?
3) How hard will it be to find the proper protection relay? How much will not having the OEM relay affect it's value? Is it worth the trouble?
4) This wooden case is really beat up, and actually cracked underneath so it's threatening to separate into 2 pieces. Is it worth the trouble and expense to try and fix up? Anyone know what the going rate is for one of these on e-pray as far as replacing it?
Thanks for any and all answers....:thmbsp:
Some questions:
