EddyR
Well-Known Member
A few months ago I picked up this set of AR3's at a antique wireless meet.They were so dirty and beat up that no one looked at them.I got them and a AR2 for $30. I later found another AR2 so I now have a set of AR3's and a set of AR2's. I took the worst box to work on first.They had huge digs all the way down to the plywood and pieces of the veneer gone. I am rebuilding the crossovers so I sanded one box down today. I went through the veneer and I didn't try and remove every bad spot.I was able to use some redwood stain on the spots where I went through the veneer and then used a restoration oil and here is what one looks like after two hr work.One midrange was bad and I have rewound the coil and I have the midrange working again. I reset the coil using tiny blocks of foam and I never thought the mid dome would work but it does. It sounds the same as the other one. This is not some thing the average person can do but I have rewound a lot of voice coils for antique speakers before. So what every though was a piece of junk will soon be like new in sound and look nice also.
Ed
Ed
Only mine are the Unfinished Pine cabinets.
