gonzothegreat
For years I've used a variac to power up suspect equipment but I've always meant to build a lightbulb jig.
For those of you in the dark about the lightbulb trick, here are the details. Put a 60W (or more) lightbulb in series with whatever gear you are testing. If it tries to draw too much current, the bulb will glow brightly and keep things from going KA-BLOOIE. The gear may not work 100% as it isn't getting full voltage.
Over at the local home improvement store (Menards) I decided to grab the parts needed to cobble one together. I discovered that building one is a five minute job with only four parts.
Parts required for light bulb jig
Two wire extension cord (preferably polarized but NPO is OK)
Westinghouse "Make-a-Lamp" kit (roughly $6)
Light bulb
Wire nut
Cut plug off extension cord and strip both wires. Screw one wire to lamp socket from kit. Screw one lead from lamp kit's cord to other lamp terminal. Wire nut the remaining leads together. Assemble lamp socket and screw in bulb. Mission accomplished!
Plug the gear into the outlet and plug everything in. When you turn on the gear, the light should briefly glow brightly then grow dim.
Considering this doesn't even require a soldering iron, *nobody* has any excuse not to have one of these.
IMPORTANT NOTE!!! REALLY IMPORTANT!!! I MEAN IT!!! YOU'LL BE SORRY IF YOU DON'T READ THIS!!!
If you are testing a VFET amp like the YAMAHA B-2 or the Sony VFET line, do not use this test device. You could possibly fry the VFETs and you'll be left with a large boat anchor full of shorted silicon.
Light bulb
Wire nut
