mhardy6647
Lunatic Member
OK, here's a problem.
Our town Teen Center received the donation of a more or less complete 1980's vintage Kenwood stereo component/rack (NOT all in one) system. This is comprised of a power amp (billed as 125 wpc and pretty respectably hefty), a 'control amp', a dual cassette deck and CDP. The power amp works fine. The CDP has issues and isn't needed by them anyway, nor is the cassette (which we didn't check out). The problem is with the preamp.
The preamp is model KC-206. It's an odd hybrid of old-school manual controls (ALPS volume pot and graphic EQ sliders) and more modern controls (electronic balance L/R pushbuttons, on/standby power switch) and it is remote controllable. Needless to say, there is no remote with it. The preamp turns on and generally goes through the motions of working, but there is no output from the main outputs, regardless of source selected. Signal DOES pass through the tape monitor loops, though.
I am thinking it's in some way related to the LACK of the remote control, or some sort of odd mode that the preamp wakes up in (see also below). I tried some of our universal remotes with Kenwood device codes to see if I could get it to do anything, but no dice.
Any insight is greatly appreciated.
I'll describe the graphic volume display below.
Thanks for your attention!
