OMI
Started the Infinity QA speaker project today. Took off all the old vinyl veneer. I have some Red Oak pre-glued veneer that I will use on them. I used a heat gun to help with the removal of the old vinyl veneer. Was expecting the stuff to be a bit thicker than it was ..
1. Heat gun used
#2 to #6 work in progress
7. first one done
8. second one done
9. pile of old vinyl that was removed from both speakers
10. Both orig speakers
Have a courner to rebuild on one of 'em.
Also have an issue with one of the tweets. Will remove the tweets and woofers to clean up the contacts later and hope that clears up the problem.
Will post pics as I stumble through this project
1. Heat gun used
7. first one done
8. second one done
