DEQ2496 is a 1/6 octave RTA, with 0.1 dB max amplitude resolution, as I recall. It's FFT, but we don't know the actual sampling algorithm. Nonetheless, smoothing is inherent in the number of "bars" it displays and the amplitude resolution, which is adjustable. As Skywave observes, it's an excellent compromise for typical hobbyist use, and more than adequate for professional applications, as well, including basic crossover and system design.
The higher the resolution and the less smoothing you apply, the more detail is displayed. That's a double-edge sword, though, with RTA; for that additional detail to be meaningful, other measurement techniques such as MLS with time-windowing or stepped and gated sinusoidal must be employed to minimize or eliminate contributions of the measurement environment such as room reflections. At high enough resolution, I can see the influence of the location of my coffee cup in the impulse response.
All of that is important with respect to characterizing and working with the response behavior of the system in isolation, quasi-anechoically. HOWEVER, bear in mind also that's not how we listen, typically. In-room frequency response, including the influence of the reflected sound field also matters; it's about compromises, balancing signal and noise. Noise matters, too.
http://www.churchsoundcheck.com/resolution2.html
What I'm saying is that the utility of high resolution depends on the measurement method and conditions as well. If we all had anechoic chambers, it'd be a slam dunk, but we don't. Key to getting the job done is understanding the limitations of each method and working within them. Study D'Appolito's Testing Loudspeakers for a more comprehensive appreciation of these factors.
Note: Most all CLIO curves I post here are shown with 1/6-octave smoothing. Check the legend to be certain. You do NOT want to try to make sense of the unsmoothed response of my typical measurements....
