It's hard to keep up with this thread. Since I am using 123A-1 woofers I felt I should chime in a little, but had to review some old stuff, return back to the top, low and behold, a dozen new posts to read.
Here's where I'm at with L100 woofers:
-Determined vertical spacing options for Econo x-over (1.6kHz) options:
12" = 41 degrees null angle
11" = 45 degrees " "
10" = 50 degrees " "
From the best we've been able to determine, the Econo PT waveguide shows about 50 deg vertical dispersion at 1.6k. No one here has measured, Zilch slap me if I'm wrong. I intend to try to see the nulls when set up with new laptop and SoundEasy, or similar.
My 123A-1s do not sound distorted. They provide fairly flat, slightly boomy bass in a 2.3 cu ft sealed box with heavy fill. That's my dumpster bin, I did not make anything from scratch.
I built Econo x-over version designed for the least efficient woofers and found my L-Pads are within the first third of operational range, meaning the woofers are not optimally matched in efficiency, but close enough.
The big issue I need to resolve is driver alignment. When early on I used the Altec Alignment method,
http://www.audiokarma.org/forums/showpost.php?p=1913628&postcount=438
I found moving the Waveguide forward filled in a gap in the crossover region. I feel this is the last issue I need to resolve.
I think the best way to do that is finally do what I've been saying for weeks, make woofer only baffles, freeing the waveguide, and find exactly where it works. W. Parham said somewhere along the line that once the delay is determined, crossover experimentation with different filters can compensate for phase alignment problems. The physical depth of the 123A-1 is very shallow, and you would think that would point the forward axis very high. If you are sitting in front of the speaker, you might well be in a deep null at 1.6kHz, or thereabouts. Zilch posits there is an electro/mechanical delay which mitigates the alignment problem. These are the issues I have using this woofer so far.
I hope I could simply move the EWG forward and leave it tweaked like that. Any issues with doing this? Reflections from the woofer hitting the back of the EWG?
I find the bass real nice from these, so I think it's worth pursuing. Maybe you guys who had problems with the woofer might check into some of these issues, of course first determining whether or not it's defective takes priority.
Re: the RTA, I think it's essential. It's been "instrumental," and I'm happy with the DEQ2496. Being a MAC guy, it was the cheapest way for me to go initially. None of the software based programs work on a MAC.
As I'm sure you know, room effects loom large in RTA measurements. I was always aware of room's influences, however this awareness is sharpened since using RTA.
It would be great to compare notes on EWG and 123A-1.
