Thanks for your support! I finished my first project (W-5M rebuild). replaced all caps and most resisters. Shout out to Steve-O for the support.I was shocked that it even worked on first testing, but It sounds great! I hooked it up to my vintage JBL for some blaring Mono...and after a couple of hours of grooving I checked the bass balance. Way off! couldn't get it to zero out. On the advice of a friend I checked all the voltages on all the terminal pins.( someone with more experiance would have done this first) The Au7's are reasonably in spec but the V3 Kt66 has no reading on 3&4 pins.(output Transformer) Also the #6 pins reading is negligable. The V4 KT-66 readings were close. and the V5(Rectifier) are a little low as my PT was a replacment and is running below spec 412-412 on the #2 and #8 pins. my question: is it harmful to run it like this ? It sounds good... Of course it would probably sound even better if I could overcome this. I'm relatively new at this, Advice?
Many Thanks,
Kirk
Many Thanks,
Kirk
