JFRogers01 said:
Then one day the potentiometer started smoking and I shut her down. I’m sure heat caused this to happen because of all the dust build up. How do I find the value of the potentiometer. Thxz for the info and encouragement.
I'll bet it wasn't because of dust. It's time to get a schematic, and see what that pot is hooked to, and what it's value is. It probably smoked because some other part is shorted or "leaking" current.
To get started, you'll want to replace all those paper capacitors. The other guys in this thread aren't kidding about that. Paper capacitors, BTW, are those tubular things that are dipped in wax. They looked in the pictures like they have bubbles in the wax. This is a sure sign they were getting hot, and they shouldn't produce any heat at all. The ones that are used for "coupling" can also destroy tubes, and believe me, capacitors are way cheaper than tubes.
You should replace them with "film" capacitors. They don't make paper capacitors anymore, except for very specialized uses. This is because paper capacitors don't last. I use Mallory 150 series film caps. Sprague orange drops are also good. Get the same value, higher working voltage is ok.
The other thing is the electrolytic capacitors. Those will be the metal aluminum things above the chassis, and possibly below. Sometimes electrolytics can be OK after all these years, but the chances are slim, especially if it's been out in the barn. You might as well get it overwith. They don't cost that much either. You will probably need to add a terminal strip underneath, and use caps that mount under the chassis. It looks like you have plenty of room. I use sprague "atom" caps for this. There are plenty of others that will work. Use the same value, and again, same or more working voltage is OK. On these you can also raise the value a little if you cant get the exact value. Electrolytics have a (+) and (-), so pay attention to that.
When you get the schematic it will probably tell you the value of the pot.
Good luck. I like the console. :thmbsp:
John
