"Ultimate" ???
Well... I've completed building the "ultimate" AM antenna.
It has proven to be the ultimate... THE ULTIMATE DISAPOINTMENT!!!!!
I wish folks would stop calling it the ultimate... its not.
FAR from.
Total waste of my time and money!
You live and learn... I learned to be skeptical of what you read
on AK.
Carver called lots of stuff the Ultimate....
None of it ever was!
Things like the MTM are a lot closer to "ultimate" level of
performance.
The main thing I've learned is: in places like rural southern
LA. a simple/untuned loop is aparently adequate, but in noise-rich
RF environments like South Florida, they're totally, utterly
inadequate!
This is a densly populated suburban, quasi urban area with
tons of noise sources both nearby and farther away.
Here, even for "local" stations, much more is needed to pull
an AM signal out of the noise!
Even a 50k watter daytime 48mi away doesn't come in without
to much background noise to listen in peace!
After going low power, (at 7pm this time of year) its impossible to listen to.
Forget any DX whatsoever. At least with the "ultimate", and
even with somewhat more powerful loops.
There needs to be a disclaimer regarding the performance of
the so called ultimate, to avoid folks running out to buy the stuff
to build one, only to have to chuck it right off, like I did.
If anyone wants mine, they're welcome to it.
It works for some... in very rural areas, I guess, but if you're
in an environment like SoFla.... FORGET it!!!!!
I've tried it with several tuners/receivers/radios.
GE-Super Radio, C-Crane radio. Mac 1900, Scott 330-D,
a Hallicrafters Communications receiver, and an Outlaw pre-pro .
All the exact same result.
It actually WORSENED the performance of some, over their
own ferrite loopsticks.
A couple of years ago I built a couple of 14 inch TUNED loops.
They're fairly simple...
Honestly.. I don't understand why ppl are afraid of them!
Or, think they're to complex.
If you're satisfied with the performance of an untuned loop,
then GREAT!
They're really not ultimate though! That MUST be said by someone...
I've wasted time and bux building one.
I could've just build the MTM and been happy for about the same $$
and time.. or a small amount more.
The 14 inch tuned loop I built was mainly meant for a reciever
with no AM antenna built in/on.
Ie: no internal or external loopstick.
Even IT is INADEQUATE here!!!!!
I built it since I didn't want anything as big as the MTM, and
felt 14 inch would be the best compromise between size and performance.
It hasn't been.
For the sake of clarity, its fine during the daytime.
That same 50k watt station 48mi away is clear as a bell
during the day... sounds like FM.
That can't be said of the "ultimate"... set in the exact same
spot, same lead wires, seconds later.
But I'm free to listen in the evening, and thats when even the
14 incher can't cut it... MUCH much less the "ultimate"!
I went ahead and built the "ultimate" ONLY because so many
here raved about its performance...
I thought an untuned loop might work because its really just
a simple "terminus" for the feed line on a receiver with no antenna
of its own.
I had begun to wonder if the inadequate performance of the
14 inch loop had to do with the receiver loading the pickup loop
to much, and that saturating the resonator.
I reasoned that, given all the hype about the "ultimate", that
it would be adequate on its own in the daytime, and work
well as a pickup loop to couple to the 14" tuned loop at night.
It taught me that the problem is one of size and power in this
noisy environment.
I also tried a Terk 10 inch loop..
Its decent for what it is... WAY to small for my needs.
Might be fine for others though.
Those who don't need all that much power.
When it comes to loops... its ALL ABOUT SIZE!!!!!
Its a question of "aperture".... or window!
The size of the window through which energy can be gathered.
(not unlike an actual window, and gathering sun-light energy)
Thats what you're trying to do, actually... gather energy!
Tuned loops just allow a large spike of voltage output at the
tuned frequency.
Try an interesting and fun experiment to experience this:
Use a radio or receiver/tuner with an integral loopstick
mounted on its rear.
Take a length of wire.. 22 guage or so.
Wrap one turn of it around a window... or better yet a very
large picture frame (window size) so you can turn it.
Mount it with p-clips or similar that will insulate.
Twist the pairs going from it, to your radio's loopstick
Wrap one or 2 turns around the loopstick fairly tightly.
Solder the ends together.
Move it along the loopstick to find the most sensitive spot.
You'll be surprised at the result.
What you have there, is 3 elements.
A (large) energy "gatherer", lead in wire, and a concentrator.
This system gathers a LOT of energy, then concentrates it on
your efficient but small loopstick.
For where I live, the 2 foot MTM will likely be the minimum
needed for adequate signal, in this miserable radio environment.
That will be my next project.
More ideal would be the 4 foot tuned loop found here:
http://www.angelfire.com/mb/amandx/loop.html
There's pix and complete building plans.
Tons of links to everything one could possibly want to know
about loop antennas and more..
Parts and supplies, and theory.
For illustration purposes, here's a link to a TEN foot tuned loop
that won DX awards:
http://www.imagenisp.ca/jsm/loop.html
That big is extreme, and larger than that gets into diminishing
returns.
Utterly impractial too.
Its roof mounted and you'll see a pic of the guy on his roof
tuning the capacitor!
:screwy:
4ft is FAR to big for inside my home, as will be the case for
most others.
Even the MTM is really to big... which is why I haven't yet
built it even though I've had the plans for a few years now.
I should have though, since nothing less works well enough
here!
RS 660, who posted earlier, should be well headed.
He's dead on, and really knows his theory!!!
His loopstick would likely be inadequate for my needs, but definately
a better choice then the so called "ultimate"!
Same preformance at the least, and very small.
His tripod mounting is almost essential for a tuned loop.
The ability to adjust it in the third plane is a huge advantage!
Tilting a loop 45 degrees from the vertical reduces noise dramatically,
in almost every instance!!!!
Small table top camera tripods are commonly available for small loops.
A full size tripod or microphone stand is a VERY good idea for 2 or 4
foot large loops!
Paul would benefit from one.
With the MTM, cut a dowel into 4 sections of sufficient length,
and 2 squares of wood to clamp the X in the center of the MTM.
Sink screws thru the corners of the squares into the 4 dowel
sections.
Add a threaded insert to match that of the tripod stud.
Bear in mind with any of these...
Using a terminal block (or anything that adds a break in lead in wire)
WILL cause a loss!
Just as in the case of splitters and couplers in FM lead in cabling..
(as seen in other related threads).
Many find it a "nescessary evil", since otherwise, the lead in cabling
is a permanent part of the loop.
Ie: you need to make the tails of the coupling loop as long as
you need to connect to your receiver.
Its obviously more practical to use a connector block so wiring
can be removed.
There IS a loss however.
Remember, you're dealing with a minuscule voltage!
Small fractions of a volt...
Very much like phono cartridge wiring.
An unbroken lead, from cartridge clips to pre-amp RCAs is
best.
Twinlead isn't the best choice.
What IS best, is small guage simple twisted pair.
Ie: 22 or 24 guage (for up to 20ft or so).
Capacitance is your enemy here!!!!
Not resistance much, though with such small voltages
its a factor of course, to a smaller degree...
22/24 guage is fine regarding that.
Adding capacitance starts tuning the loop!
Weather its a tuned or untuned loop.
If untuned... you don't want to tune it.
Especially not with random values.
If tuned... you don't want to de-tune it with extra capacitance!
Remember, tuning a tuned loop involves a few PICOfarads.
Adding anything to a wire.. or pair of wires adds
capacitance... IN PICOfared values!!
A simple pair of thinly insulated wires is the least harmfull.
Again, its a fraction of a volt.
Twisted pairs offer almost as much noise rejection as sheilding!
With voltages this low, good connections are essential.
Small/thin spades (crimped and) lightly soldered on offer
low resistance and good connection.
Experimenting with bare wire ends in screw terminals will quickly
teach this lesson.
I strongly recommend thin guage twisted pairs for your "lead in",
with soldered on spades.
Radio shack offers spades sold as "telephone spades" from
Radio shack. Cat #64-3070 that work very well.
They're small and very thin, for low resistance.
(not thick/huge high current speaker spades)
Crimp, then let a tiny bit of solder flow in.
Suggested tuning method for tuned loops:
I honestly don't understand why some find it so difficult.
You get the feel for it very quickly.
Turn the knob medium fast thru the cap's range..
(once the receiver is tuned to desired station)
You'll hear a kind of "schooop" sound when you pass the peak
tuning spot.
(or see your S meter jump)
Turn the knob backwards slowly to find that spot.
The signal will jump out at you... can't miss it.
Small movements back and forth in that area will fine tune it.
It should only take one or two slow sweeps to fine tune it.
Thats it!
Another way, is to add a vernier to the tuning cap shaft.
Google vernier to find one.
A bit pricey though, but makes it much easier.
I personally find it totally unnessary though.
Paul's MTM might benifit from re-locating the pickup coil a little
further from the main loop.
2 inches perhaps. Maybe even 3.
Ironically, there's a bit more voltage transfer with them further
apart... up to a point.
Note that MTM has recently added a link to their page.
"Many have requested" a pickup coil with taps for receivers
with no loopstick.
They one they recommend (with photo, btw) is 6 inches in diameter.
Here:
http://www.mtmscientific.com/pickup.html
Do the math, and you'll see the relationship between 6 inch diameter
inside the main loop, and the main loop itself.
Might want to experiment with 2 turns too.
Experimentation often pays off with this, as the behavior of the
voltage transfer is hard to predict... particularly with different
radios/receivers.
It might even have the effect of widening the tuning range or
making it a bit less sharp.
I've attached a file to this post.
Its a handy little program called Loop Calc.
Its small and simple and allows you to calculate just about every
parameter for designing your own custom tuned loop.
You fill in boxes for such things as freq-range, loop size, and
just about every other parameter.
It calculates the rest for you.
Hope it helps!
TUNED loops REALLY ARE the way to go!!!!!
If you want to know what is REALLY the ultimate AM antenna,
try this:
http://www.wellbrook.uk.com/products.html#ALA1530
Reviewed here:
http://www.radiointel.com/review-wellbrook.htm
I appologize for the length of the post, but I just HAD to vent!!!
I've had these thoughts on my mind all week.
Spent much of last weekend making the ultimate.. and
a good chunk of spare cash on a total failure, when I could
have the MTM right now... all I need is the wood.
I'll shove it under the bed when not listening thru it.
I only hope that some of this hard learned information is helpful
to someone!
I've certainly determined which direction *I* need to go in for "ultimate"
AM performance!
Its the MTM.
Greg
