Just my .02 here, but EV 12L plays well up to 2k and beyond, unless you're driving them with low power SET's, i'd be crossing the 808/811 a lot higher than the 800hz cutoff of the 811 horn, probably something in the 1200-1500hz range.
The 811 horn certainly behaves better at 1200 Hz than 800 Hz. (511 is better at 800 Hz than 500 Hz, also.) Altec moved the crossover frequency for 811B horns to 1200 Hz in Model 19 and subsequent designs.
What several here have not yet noted from the work Steve O and I have done with 846 Valencia et.al. is that the crossovers are NOT symmetrical at 800 Hz. They were, initially, but Altec early on moved the HF highpass considerably higher to attenuate (somewhat) the excess midrange response of the compression drivers. See the actual response measurements with the 846 highpass in the post I linked to above, which shows the behavior of the 806A driver on 811B horn both with and without the 846 highpass filter. Note how it knocks down the output between 800 Hz (the ACOUSTIC crossover frequency) and 3.5 kHz:
The ELECTRICAL crossover frequency is NOT 800 Hz. If you use a symmetrical crossover (lowpass and highpass at 800 Hz) as suggested by others here, and as initially used by Altec, without additional HF compensation, you generate Altec upper midrange "Shout" in full measure. I don't believe it matters which motor or diaphragm is used, the phenomenon is characteristic of compression drivers themselves, generally, and you must employ compensation, either passively or actively, to achieve flat frequency response:
http://audioheritage.org/vbulletin/showthread.php?t=4410
It is SO characteristic, in fact, that most active crossovers and many pro amplifiers accordingly incorporate HF compensation (EQ) circuitry for use with compression drivers and horns. In the Behringer I have referenced in that link, you push a button to accomplish it. While it can also be implemented passively (Tom uses the Altec T-filter circuit, I noticed in one of his posts,) I'm suggesting that Spaceman invest the requisite few extra dollars ($130 PE list,) involved in going active biamped and securing control of his new 811Bs from the outset.... :yes:
Next on my agenda is a mic, a new RTA and a pair of Emilar 175s.
Go, Tom, GO!!! :thmbsp:
