ecluser
First let me say I am a Yamaha lover, and I don't want to offend any other member of "the familly" by this title.
Let me say also that I don't think there is any particular problem with an offset as low as this. A 60mV offset in a 3 Ohms load (typical DC resistance for a 4 Ohms speaker) represents only 1.2 milliwatt of power, and only 0.6 milliwatt in a 6 Ohms load. There is nothing here to justify all the attention a small offset like this received on some threads!!
I don't think Yamaha designed this receiver with a -61mV offset goal, but they certainly figured it was inoffensive. I think so...
As a Yamaha lover, I was curious to find why others CR-420 owners frequently measured an offset in the vicinity of -60mV. I was also curious to see if there is a solution to this.
As an intellectual exercise, here is an analysis of the problem. If you don't want to follow the math section, you may skip to the end of this thread, where you will find a very efficient and easy to implement solution, or you may jump to another thread!
You will find a complete and very readable schematic for the CR-420 here:
http://www.hifiengine.com/manuals/yamaha/cr-420.shtml
For the sake of simplicity, I've reprinted part of this schematic (part of left channel only) and I've added some informations like measurements, computed values and formulas to it. I suggest that you print the first attach file to follow this analysis. (The value for Vb3 and Ve (TR403 TR405) on this file is computed after a change in R407)
In this analysis, I make some reasonable simplifications and assumptions:
Vbe = 600mV for all transistors
Ic = Ie for all transistors
hFE = 300 for TR403 and TR405, corresponding to the mean value for the 2SC1571 F or G, the original transistors.
The first step is to compute the bias current across the Vbe multiplier, to see if the base current from TR407 can be neglected in the actual value of Ic3 (Ic3 is the collector current in TR403).
At standby, the emitter of TR409 is at -1.2V since there is 4X0.6V across the Vbe multiplier. This bias current is set by R421 and R423 and the -30V supply rail at:
I= 28.8V / 4.4kOhms = 6.55 mA
This is the current across TR407. I figured a hFE of 200 for the 2SA659 and to be sure, I measured the voltage across R413 and found 16mV on both channels. This translates to a base current of only 34uA from TR407, not far from 6.55 mA / 200, and I neglected this current in the rest of the analysis since it represents only 3% of the estimated value for Ic3.
Now, we need to compute the exact value of Ic3 because this value sets the base voltage for both transistors (yes, both) in the differential stage.
From TR401, R405 and R407, we have
100 Ie1 + 0.6V = 1200 Ic5
Posing Ie1 = Ic1 = Ic3 since Ic3 and Ic1 >> 34 uA
Ic5 = (100 Ic3 + 0.6 ) / 1200 = (Ic3 / 12) + 0.5 mA
Here is the problem! With this value for R407, Ic3 is about 3 times larger than Ic5 (we will see this later)
Also, Vb3 = - 18270 Ib3 = - 18270 Ic3 / 300 = - 60.9 Ic3
Ve for TR403 and TR405 is given by the supply voltage (-13.7V) and R411
Ve = - 13.7V + 5600 (Ie3 + Ie5).
It is also set by Vb3 and the Vbe voltage
Ve = Vb3 - 0.6V
We have three variables, Ve, Ie3 and Ie5. We have also three equations. Easy to solve!
Ve = - 13.7V + 5600 (Ic3 + Ic5)
Ve = - 13.7V + 5600 (0.5mA + (13 Ic3 / 12))
Ve = - 0.6V - 60.9 Ic3
Solving the two last equations by subtraction to get rid off Ve, we get
Ic3 = 1.68 mA
The rest follows like spring water
Ib3 = 1.68 mA / 300
Vb3 = - 18270 (1.68 Ma / 300 ) = - 0.10V
Ve = - 0.70V
Ie3 + Ie5 = (13.7 - 0.7)V / 5600 = 2.32 mA
This is the Tail current, It
Ic5 = 2.32 mA - 1.68 mA = 0.64 mA
Ib5 = Ic5 / 300 = 0.64 mA / 300 = 2.14 uA
Vo, the output voltage at standby is
Vo = Vb5 + R415 Ib5 = - 0.1V + (18000 X 2.14 uA) = -0.1V + 0.0385V
Vo = - 0.0615V = - 61.5 mV THIS IS THE OFFSET VOLTAGE for perfectly matched transistors in the differential stage of a CR-420.
As you can see, the problem is because Ic3 = 2.63 Ic5
But a solution exist if we can make Ic3 = Ic5, and it is very easy if we replace R407.
Posing Ic3 = Ic5 = It / 2 = 2.32 mA / 2 = 1.16 mA , we have
R407 x 1.16 mA = 0.6 V + (100 x 1.16 mA)
R407 = 620 Ohms
With this value, the base current for each transistor in the differential pair will be 3.87 uA
Vb3 = Vb5 will be - 71 mV
Vo will be
Vo = - 0.071V + (18000 x 3.87 uA) = ZERO !!!
A practical solution:
I've bypassed R407 with a second resistor, soldered on the copper side of the printed circuit board. The exact value for this resistor was selected by experimentation because I did't try to match the transistors in the differential pair.
With needle nose jumpers, I shunted the original resistor with another resistor starting with a 1200 Ohms. See the pictures on the attach files for the Left and Right channel positions for R407, R408. Turn the receiver OFF when you put the jumpers in place, the spacing is very small here.
The advantage of this method is that once the jumpers are in place, you can trim the value of the additional resistor with the amp ON.
My results?
Original Vo R Ch = - 61mV, -4 mV after shunting R407 with 1200 Ohms
Original Vo L Ch = - 51 mV, 0 mV after shunting R408 with 1300 Ohms
Good tweakings in your CR-420 !!
I am quite confident that replacing the original resistor (R407, R408) with a 620 Ohms resistor, if you have well matched transistors in the differential pair, you will have very close to 0V offset voltage in your CR-420.
(edit on 2014-04-12: take a look to this thread http://www.audiokarma.org/forums/showthread.php?t=578021&page=4 )
Ve = Vb3 - 0.6V
Ic3 = 1.68 mA
Ib3 = 1.68 mA / 300
Ve = - 0.70V
R407 = 620 Ohms
Vo will be
My results?
