Yamaha CA-1010 : Class A mode
triodo
I have a Yamaha CA-1010 amplifier : It's seems working correctly in Class AB mode but as soon the operation selector is switched in Class A mode the volume level decrease a lot and the sound becames distorted.
Do you have suggestion?
Thanks in advance for your help!
Yari
If any of these dual mode Yamaha amps are switched between modes with the power on it eventually damages the switch. In the CA-1010 the switching is done by a relay so it is possible the relay contacts have become pitted and dirty.
Marrylander, first of all ....
Thanks ....!!!
I found the relay on the wiring diagram.
Do you think that I could try to clean it using a contact cleaner (Philips 390CCs spray)?
If is necessary to replace it : Is still available the relay as spare part?
I'm finding in this amp a very good sound.
I hope to repair it.
Thanks again
Yari
If you can get the cover off clean the contacts with a burnisher or fine grit (600) emery paper then clean them of any dust. I think DigiKey is carrying some of these PC mount relays.
thanks for the great support!!
Tom, I see that you also have a CA-1010 ....
Do you think that is necessary to check also the bias values?
Other suggestions for a good setup?
Thanks
:yikes:
Oh, for crying out loud! I looked online for three solid days for that Panasonic part, and all I could find was used! Thanks for finding that!
Well, you should have PM'ed me ..:lmao: I bought 4 of them a while back and they are the real deal...
Thanks
Yes, the bias should be checked to make sure it's correct. I had to adjust mine. A side benefit was that DC offset was reduced, too! :) That's helpful, because offset is NOT adjustable on a 1010.
Also, I recommend using contact cleaner on all the switches and controls, cleaning the RCA jacks on the rear, renewing all the meter lamps if needed. I find I need to use contact cleaner every 18 months or so.
Tom
Pfft. Now you tell me! Where were you last September?
Meh. Well, what's done is done... I can't complain about my results. Thanks anywho!
Regards from Tom
