jackgiff
Well-Known Member
A tutorial on etching printed circuit boards.
With the proliferation of DIY speakers, building professional looking crossovers is becoming more important to many builders. Numerous ways to assemble crossovers exist, but many are difficult to implement, or duplicate. Printed circuit boards solve most of the problems, making it simple to build professional looking and easily duplicated crossovers.
There are several vendors where printed circuit supplies can be purchased. Parts Express is a sponsor of AudioKarma, and sells presensitized PC boards, and developer using the “positive” system. Other vendors have supplies for both “positive” and “negative” systems, as well as developers, etchants, and equipment to make the job easier. Many vendors have “Do-It-Yourself” tutorials on how to etch their PC boards, but they all want to sell you all the equipment they feel is “necessary” to make the job easy. Since the average DIY’er is going to be making only one or two pairs of boards, investing hundreds of dollars in special lights, holders, and etching tanks with their assorted heaters and bubblers doesn’t really make financial sense.
Positive systems mean that where light can get through the artwork, copper will be removed from the printed circuit board. Negative systems means that where light gets through the artwork, copper will be retained. A photo positive is required to expose artwork in the “positive” system, and a photo negative is required in the “negative system. The presensitized boards and developer from PE are "positive" system components. They are slightly more expensive, but eliminate several steps. The “negative” systems all use raw PCB’s and allow you to spray on sensitizer before exposing them. If a mistake is made, you can then clean the boards, and start over. With the “positive” system you only get one chance to expose and develop the board properly. The “negative” system also adds cost of sensitizer, so the overall cost of building boards is roughly the same.
Etching your own circuit boards doesn’t have to be a costly process. Who needs special lights to expose his layout, when we all have the sun. A special holder is not needed to hold the board during exposure, as long as a little care is used. And an etching tank with heater and bubbler would be great if we were going into production, but for just a pair or two of PCB’s, they are not necessary, but not using them may add 10 minutes of time to the process.
This tutorial will detail the way I make PC boards, and it will not call for any special equipment. It is done on the “cheap”. The equipment I use is as follows:
Pyrex pan for developing and etching.
Piece of glass for holding artwork and board during exposure.
Book to support the artwork and board during exposure.
Presensitized PC board of correct size.
Artwork or photo positive.
Etchant solution.
Developer solution.
Measuring device for preparing developer solution.
Folded blue cloth towel.
Drill and bits to drill holes in PCB.
Piece of steel wool to remove photo resist from etched PCB.
Double Stick Scotch tape.
PCB material for guides (or any thin stock).
Popsicle stick or wooden pencil.
Rubber Gloves if you are sensitive skinned.
The Pyrex pan I use is roughly 8 inches by 12 inches and 2 inches deep. I stole it from mama’s kitchen years ago. You probably can steal one from your own kitchen or pantry.
The glass for holding the artwork and board should be about one or two inches larger per side than the PCB you plan to make. Larger is OK, but more difficult to keep in place during transport. I bought a new piece at the local glass shop which is 6” by 8” and ¼ inch thick. I used to use a big piece of seeded glass, but felt the tutorial would be better with a reasonable sized piece of clear glass. The bubbles in the seeded glass did not affect the exposure. The new piece of plate glass cost $2.50.
Virtually any book larger than the PCB will do, since it is just to provide support for the board, artwork, and glass during transport and exposure.
The folded cloth towel is simply one removed from a roll of shop towels that can be bought at any hardware store. The ones I use are blue in color. Yours may vary. It is used to provide some support for the board during exposure.
The presensitized PC boards, developer and etchant can all be bought in many places. This tutorial will use PCB’s and developer from Parts Express, and etchant (ferric chloride) bought from Capital Electronics in Phoenix, Arizona.
Picture 1 shows all of the supplies needed to etch your own PC boards, except for the drill and bits, and rubber gloves. Picture 2 shows a closeup of the etchant and developer.
Etchant solution.
Developer solution.
I can see it now, boxes and boxes of request and purchase orders litter the front lawn,
