Minimus 7 Loudspeakers - Measurements
Zilch
Curve Junkie
Mod Summary:
http://www.audiokarma.org/forums/showthread.php?p=3671070#post3671070
Before vs. After frequency response:
attachment.php
Baseline, unopened:
attachment.php
Including woofer on-axis nearfield 1/8" in front of grille, -32 dB:
attachment.php
Compare to Murphy's results here:
http://murphyblaster.com/content.php?f=minimus.html
attachment.php
Uncanny...! :thmbsp:
Edit:
History of The Minimus 7 Family
Minimus 7, 1978 to 1993, Models 40-2030 Black, 40-2034 Silver, 40-2039 Wood, 40-2045 White
Pro 7, 1994 to 1996, Models 40-2066 Black, 40-2065 White
Pro 7AV, 1994 to 1998, Models 40-2048 Black, 40-2059 White
Pro X7, 1995 to 1998, Models 40-2071 Gray, 40-2076 White
Pro-X44AV, 1999 to 2000, Models 40-2080 Black, 40-2081 White
The tweeter design was changed in 1983. The name was changed from Realistic to Optimus in 1994.
http://www.angelfire.com/vt/audio/minimus.html
Zilch, that's really impressive...
Got a pair of -12's to compare? I've never heard the 7 but am listening to the 12 now and I am blown away....unfortunately I think I just popped one tweeter with a turn on blast.
Are you thinking external crossover (mounted in-sub), 2nd or third order and some compensating filter to extend the highs?
:scratch2:
Then get that sub thread rolling and we're in business....
:scratch2:
If there's a sub, I'm definitely going to try to build it, as I am designing a rolling sound cart for recording live mixing, and I can easily integrate a small sub along with the planned 7's as nearfield over-desk monitors.
We have lots more to learn about them yet; there are three existing mod proposals to compare. By the time that's done, we may know enough to fix them.
I have played them with JBL Control SB-5 and Accurian amp. That worked nicely, but these measurements suggest that the Minimus 7s are not themselves adequate for use as monitors.
Yet.... ;)
There was a period when I had a standup MIDI/mixing setup in the corner of a studio apartment and primarily used Minimus 7s. They are similar to NS-10s in that they have little deep bass, but in that corner, they worked fine, despite the limitations, you could work with them. I had no sub. Still have the 7s in a box somewhere.....
We have lots more to learn about them yet, and there are three existing mod proposals to compare. By the time that's done, we may know enough to fix them.
I have played them with JBL Control SB5 and Accurian amp. That worked nicely, but the Minimus 7s themselves are not adequate for use as monitors.
Yet.... ;)
Following with interest.
I don't have enough to build a wall, however.
Dig 'em out, Skywave, and play along with us here.
Let's see what model you have, and if your RTA measurements corroborate Murphy's and my findings.... :thmbsp:
Yet.... ;)
Definitely following this thread with intense interest.
I use -12's as monitors, but since I fried a driver (I think..still listening), I am even more interested than I normally would be.
I googled the Control SB5 and it came up with a 3 driver monster of a sub that would not be comparible with the 7's size...I am in need of a compact, cheap, rugged, solution for live and "studio" (I don't have a studio, so I try to get 2 adjoining rooms in my school to record in when I record, ahsn't happened yet) monitoring....
http://www.jblproservice.com/pdf/Control Series/Control SB Micro.pdf
http://www.jblproservice.com/pdf/Control Series/Control SB-1.pdf
http://www.jblproservice.com/pdf/Control Series/Control SB-5.pdf
eBay, ~$50.
Zilch, I should have my measurements up here in a day or two.
It will be interesting to see how consistent they turn out to be. :thmbsp:
here are detailed pictures of my 1991 M7's with the ebay crossover modification; I used these for mixing and thought they were great.... still going to use them for that "NS-10 sound"
http://76.176.179.210/minimus
Man, I'm such a noob, how do i make those readings? I want to see how my M7's compare!
