tubino
A guy with too many tubes
What I did this weekend
I recently acquired a pair of new 2226 and used cabs from speakerman. The 2226 needed mechanical break-in, so I unloaded them straight into my garage loft/workshop. Hooked up the first SS recvr I stumbled over, a Pioneer SX-550. The bass was kinda obnoxious in the house (detached garage! 20+ feet away!), so I wired them out of phase and faced them at each other with ~8" between, standing on 2" thick fiberglass panels, and put the receiver on MONO. Really remarkable how well the cancellation works then!
But when I had work to do up there, I thought I should have TUNES!
Found two crossovers I made for a project, complete with Lpads and 10uF cap for the HF. Replaced the 2.7mH coil with a 1.2mH for the LF. I flipped the JBL cabs upside down, took some unused 902 drivers and Martinelli horns and hooked it all up.
Very promising! But I had to get those bass boxes working right, so cut two boards to fit over the rectangle where a horn had been mounted. To mark the holes, I threaded screws from behind until 2 threads showed, mashed board in place to mark screw holes, drilled both boards at once and mounted.
The 2226 are still breaking in, but even now I've got great workshop tunes! I thought these would go in the house, but they might have a life in my workshop!
