The Technics SL-23 arrived OK, nice packing job by the seller.
Pictures will follow once I have it on the bench , it needs a belt and headshell w/cart.
Thanks,
John.![]()
While you're at it, I suggest you install some quality interconnects and deoxit/faderlube the pots. All very easy to do on the SL-23. Plus make sure you purchase the correct size belt or you'll be chasing the pitch (speed) control all day long.
I have/had two of these, one as the original owner in 1977 which I still use. Refurbished them both over the time and they play and sound very good. But they are very susceptible to hum with the original interconnects.
I gave my second SL-23 to my son for his birthday present this Feb. and he is happy as can be with it. :grnbounce He now has the bug and since then lucked into a nice collection of very clean LP's and a pristine pair of Klipch Fortes for free. :thmbsp:
If you can, check with the owner to see what brand of cables he installed. If they are just audio RCA like you use to hook up components, the capacitance is way too high for phono use, measured and proven by member Hakaplan. Component video cables offered by Petra and MonoPrice have a lower capacitance/foot often superior to original TT interconnnects improving the sound quality and negating hum potential because of their shielding. I use the MonoPrice because of the cost and flexibility of the cable. Replacement on this TT is as easy as it can get compared to others I've have done.The owner has already change the RCA cables and put Gold ends on them, that was nice, and I have not ordered my belt yet, or cartridge. BTW, what cart did you have on yours?
Thanks for the Heads up!
Thanks,
John.![]()
I currently use an AT 440ML/occ on my SL-23, but would suggest the 440MLa because the highs have been toned down a bit to make them easier to listen to with different recordings.
What do I need to measure the cable capacitance and how do I do that?
I have a AT440MLa on another table here, sounds awesome.
Thanks,
John.![]()
You can't really measure capacitance without a capacitance meter which are usually pretty expensive. You can however use a pair of thick looking video interconnects and be more or less comfortable knowing they'll do the job. As long as you don't use a pair of flimsy skinny interconnects you'll be ok.
The only thing on these turntables is the speed pot gets crappy and dirty and it'll make the speed unstable but as soon as you clean it out it'll be rock solid again just like back in the 70s when it was new.
I worked on mine some today. I'm getting a lot of static-y noise, but I'm not sure if it's the TT or the receiver (Sansui 2000X) I'm running it through.
Gonna try it through another amp tomorrow. If it's still noisy then I guess the next likely culprit is the cartridge or stylus? Or the interconnects? (It has the original ones.)
I'm kinda new to all this, so diagnosing problems is, er, a problem for me sometimes.:stupid:
You have learned a lot on AK. The problem lies in one of those three or related. You want to check to make sure the headshell wires are intact, making contact, and properly connected. Try wiggling the interconnects and see if that changes things. Make sure the stylus is fully seated in the cartridge. Remove it and reinsert it. And while we're on that topic, what is the cartridge? Is the stylus new? Is it clean?So it's something on the turntable. Should I get a new stylus next, new cartridge, replace interconnects or am I chasing some other gremlin?
I agree 100%
