A-534B - 300B tubes - listening tests, note that this post was origianlly written Jan. 2009.
Grant Fidelity A-534B 300B tube amp, MBS-1 speakers, MDVD-100 CDP, MRCA-1 interconnects, SPC-2.5 speaker cables, RPF-120 Conditioner, PC-1.5 Power Cables, 2 x BT-12 Bass Traps.
300B tubes tested:
Shuguang 300B-98 - Retail $160 USD Pair 30 day warranty at GF.
TJ Full Music 300B/n Mesh Plate - Retail $285 USD Pair 30 day warranty, $325 USD Pair with one year warranty at GF.
TJ Full Music 300B/c Carbon Plate - Retail $459 USD Pair 30 day warranty, $499 USD Pair with one year warranty at GF.
Shuguang Treasure Series 300B-Z - Retail $600 USD Pair 30 day warranty, $650 Pair USD with one year warranty at GF.
TJ Full Music 300B/se Carbon Plate - Retail $700 USD Pair 30 day warranty, $750 USD Pair with one year warranty at GF.
Other tubes tested:
TJ Full Music 12AX7 Box Plate - Retail $110 USD Pair 30 day warranty, $130 USD Pair with one year warranty at GF.
Shuguang Treasure Series CV-181Z (6SN7) - Retail $320 USD Pair 30 day warranty, $345 Pair USD with one year warranty at GF.
Started with the A-534B with stock tubes. Music used is my GF demo disk, which goes every where with me. Female vocal and jazz quartet, then male acapella quartet, then sax with jazz quartet, then full orchestra doing swing, then female pop song song. I used to be a recording engineer so I can focus on particular parts of the mix and memorize them. The tubes would all be on for 15 minutes prior to listening, amp was warmed up for an hour prior to tests.
The purpose of this review is 2 fold, to get a feel for upgrading the A-534B with tube rolls, using the tubes we now carry and to evaluate the difference between the 5 330B tubes we carry. The results are not definative and should be used just for making up your own mind. I have tried to step back from the fact that I sell these tubes and the amp to provide what differences I heard when rolling and that is what will follow, just my notes, whatever I wrote while listening.
I ran the A-534B at the same volume for all tests which was a bit louder than typical listening, probably about 90db average, 4 on the volume, in the 1 to 5 watt range. I started with the A-534 with the stock tubes and then started rolling, where the amp ended up completely retubed and then worked my way back to stock. I didn't do the recifier tube, as it just introduced too many variables for this test.
The TJ tubes had decent time on them except for the TJ Full Music 300B SE which Rachel sold to a friend, a new set seemed to sound great even after 15 hours so went with it with low hours. The Shuguang Treasure 300B-Z has only about 40 hours on them and the factory says 300 hours to burn in. The Shuguang Treasure's sound very tight new and loosen up after about 15 hours. Other Shuguang Treasure's are still improving daily with over 100 hours on them. IMO the 300B-Z has not yet shown me it's full potential at all.
First Roll - TJ Full Music 12AX7, replacing Shuguang 12AX7B in pre-amp section. My notes:
Wow, more of everything, much more bass extension, soundstage opens up, more detail and more apparrant gain. Remained in for rest of tests.
Second Roll - Shuguang Treasure 6CA7-Z (EL-34) Fat Boy replacing Shuguang EL-34B in driver stage. My notes:
Nice, more solid bass, darker soundstage, less distortion, less sibilance, more air. Remained in for rest of tests..
Third Roll - TJ Full Music 300B/n Mesh Plate replacing Shuguang 300B-98. My notes:
Taller soundstage, much more air, more snap on bass, deeper soundstage, more upper frequency detail, really nice and fun tube, only about $100 more a pair than the Shuguang 300B-98, make this a no brainer.
Fourth Roll - Shuguang Treasure 300B-Z Mesh Plate replacing TJ Full Music 300B/n mesh plate:
same tonal character as the TJ, less distortion, more balanced sound, really like, cannot stop listening, midrange is very sweet but accurate, more relaxed, need more time on tubes, they sound like they have much more to offer.
Side note on the Shuguang Treasure Series, the internal High Polymer Compound Carbon coating is alive. When new, the coating is not complete, after you run them for a bit the coating expands into place, very cool to observe.
Fifth Roll - TJ Full Music 300B/se Carbon Plate Special Edition replacing Shuguang Treasure 300B-Z mesh plate. My notes:
Just perfect, just right amount of air, soundstage opens up beautifully, more bass extension, sibilance gone, amazing layering in soundstage, hard to reproduce passages done with ease.
Sixth Roll - Shuguang Treasure 300B-Z Mesh Plate replacing TJ Full Music 300B/se Carbon Plate Special Edition. My notes:
Tighter sound (as in tight sounding tube), smaller soundstage, still sounds like not enough hours on tubes, soundstage more forward, but beautiful sound, again hard to stop listening, something magical in the coating, less distortion, most accurate tube, excellent imaging.
Seventh Roll - TJ Full Music 300B/c Carbon Plate Standard replacing the Shuguang Treasure 300B-Z. My notes:
Not as much air, very balanced sound, roundish bass, smaller soundstage, very smooth, really nice tube, doesn't seperate complex passages like the TJ SE or SG 300B-Z, very full sound, good for a thin sounding system.
Eighth Roll - Shuguang Treasure 300B-Z replacing TJ 300B/c. My notes:
Air is back, better defined bass, sibilance gone, really sweeet tube, better soundstage, better instrument seperation, better than the TJ 300B/c in just about everything.
Ninth Roll - TJ Full Music 300B/se Carbon Plate Special Edition replacing Shuguang Treasure 300B-Z mesh plate (again). My notes:
hotter tube, plays a bit louder, this is the best tube, nice growl in bass not noticed in other tubes, accurate imaging, so musical on sax, difficult orchestra sounds amazing, love this tube.
Tenth Roll - TJ Full Music 300B/n Mesh Plate replacing TJ Full Music 300B/se Carbon Plate Special Edition. My notes:
Aggresive sound, nice but hollow, very forward soundstage, want to turn it down. Hard to listen to after SE.
Eleventh Roll - Shuguang 300B-98 replacing TJ Full Music 300B/n Mesh Plate. My notes:
Bass round and flat sounding, imaging not as accurate, no where near as much air, nice balanced tube.
And that is it. Again it is up to you which tube fits your budget and sound. I can make basic recommendations, if money is no object, go with the TJ 300B/se or Shuguang 300B-Z, both are amazing with the edge going to the TJ 300B SE in my gear with my ears. If you are on a tight budget, spring for the TJ 300B/n mesh plate, it is an excellent budget tube. The TJ 300B/c Carbon Plate is an excellent tube, it has been reviewed in the past as being better than the expensive WE, but is not in the same league or as listenable after hearing the TJ 300B/se or Shuguang 300B-Z.
For A-534B owners, please consider getting a set of the TJ Full Music 12AX7 tubes for your amp, this will make the most improvement for the least amount of money and still retains the magic of the A-534B in stock form.
When I have 300 hours on the Shuguang 300B-Z and can get some extra sets of ears present. I'll do a shoot-out on the Shuguang 300B-Z and TJ 300B/se to see who gets top spot with the A-534B. For those that have already purchased our 300B tube offerings, would appreciate hearing your opinions.
Rest of the thread is here, including final recommendations and other opinions:
http://grantfidelity.com/forum/viewtopic.php?t=281
Cheers,
Ian
