My new Sub DIY
drz01
Just finished making these babies tonight. you can judge the size by the cd on top. It has a 15" dual voice coil driver at 6 ohms. My Sansui b-2102 power amp is driving this baby..
Well it's late at night and I have neighbours :thumbsdn: but at low levels it sounds sweet and very deep. I auditioned Tracy Chapman Fast Car, Vangelis Jerusalem and some James Newton Howard. With Chapman the bass is a deep synth bass and it was conveyed very well Vangelis has an organ note that is around 16hrtz and I felt it, Howard has the best recorded drum set i ever heard and was natural sounding without being tubby. I will give a better review when I play it at a better listening level.
Here is the bottom (the works)
Ain't DIY yhe very best way to get the performance you want in a sub?? I built mine in January. I would not consider a store-bought one again.
Hope you enjoy yours for years to come.
Nice job. Did you work off of plans or design it yourself? How is the expence compaired to buying a manufactured sub?
cubdog
I used the guidelines from the speaker maker to design the size of the enclosure. It is 3/4" MDF covered in velvet like carpet and to make it wife friendly I will be getting a smoked glass top for it. Since it is daytime now I pushed it a little more and got the china cabinet shaking :naughty: I have to dig out Telarc's Time Warp to realy here how deep and loud this baby goes.
What driver do you have in there and how much did it cost? I am looking for driver(s) for sub application as well
The driver is an UltraLinear ULD615 15" driver. It has two 6 ohm voice coils it's basket is made of alumimum so it rigid strong but light. I have been pushing it for two days now and wow compared to store bought subs with the typical 8 to 12" drivers. BTW the driver was a resonable $80.00 and the box cost me all of $40 dollars in material and that is Canadian dollars.
Thought I’d jump in here and show you guys the sub I built. I designed the box for a 17Hz cutoff for my HT system. I’m using an old Phase linear amp to drive it. At moderate SPL it sounds great. I used some 12” MTX car stereo drivers I got at best buy for cheap. It originally had 1 12” driver but have since upgraded to two. I made measurements; it’s flat within 3db from 17- 80Hz.
DRZ01
A few questions as I do not know much about subwoofers and how they fit into a two channel stereo system.
Is your Sansui b-2102 power amp dedecated only to the subwoofer and do you have another amp for you main speakers?
Is the dual voice coil used one coil per stereo channel?
How do you wire up the subwoofer with your mains? Do you drive the mains on say A speaker connection and subwoofer as B?
Thanks
Charlie
Ohhhh, that's nice drz. I suspect I am after the same info as Charlie. I was following his 2.1 thread. I'm thinking my Dynaco A25s with a sub would be perfect.
Ed
CharlieBee said:
DRZ01
Thanks
Charlie
The Sansui B-2102 is driving only the sub, one channel per voice coil. Since each coil is about six ohms each channel of the amp is capable of putting ot about 350 watts rms. My main speakers is driven by a Sansui RZ-8300AV receiver which has a sub channel out (pre amp out) but I do have an electronic crossover before the poweramp to control the crossover point which is set at 75htz. So in essence I have a 2.1 system
mmmmmmmm our classic xs cargo sub.... what city? those are suprisingly well made subs, i've got one around here i need to put in a box.
Toronto and I got the last one at the store ...
