I'll try to get a better pic tomorrow if I can, but here's my thoughts...
KA-7100's are as common as fleas on dogs, but that does not keep them from being one of the best bargans on eBay and elsewhere. I've said before that all the 7100 lacks to be a real contender is pre-out/main-in jacks. I added them to
hpsenicka's 7100, but mg196 passed on it, as not everyone has a real use for 'em. My only criticism of the 7100 besides the lack of seperate jacks for the preamp/amp is the low filter...it uses a simple RC filter with such a gentle slope as to be near useless.
Army found this one..........and snagged it for all of $30. The front panel and knobs and all are flawless. The wood case is an easy 9 out of 10. This is the nicest 7100 I've ever seen.
All the electrolytics were replaced with the exception of the large power supply caps, which were fine and given 2.2µf film bypasses. The signal path caps were replaced with BlackGate caps (including the phono stage), and the rest are Panasonic FC caps. The relay was pulled and cleaned, the transistors pulled and cleaned and new HS grease applied, and the bias 'n offset pots replaced with 25-turn Bourns units. I also fudged with the turn-on relay timing so slow it down a bit...helps keep the speakers from getting a 'thump'.
The unit clipped at 83WPC, and distortion at 60WPC measured 0.003% @1KHz, which is essentially the residual of my analyser. Very nice.
It it's decent out tomorrow, I'l see about getting a pic in natural light. Flash pics of silver gear never look good.
