approx 2 weeks ago I answered a CL for what looked to be a '57 CE II. Let Red, Naptown and Fran know about it.
The owner also advised me that the chassis said R-3 on the Tag. But that isn't what's in a CE II.
Anyway the owner took my offer and after finally getting our schedules in line (shades of astrology here), I showed up at the owners place. There in the Living Room sat the Console.
Opened it up and immediately noted the missing speaker. She stated that it was taken by a cousin prior to her getting the console about 10 years ago. Last that she knew it was running was approx 15 years ago.
A closer look provided the clue that RED had provided, thinking it was the Rare and almost mythic CORONET. There on the Front panel under the center of the DIAL Glass is a Brass colored applique with a CROWN and FISHER printed under it.
All tubes are intact. The power cord is shot. The turntable is a WEBSTER CHICAGO Model 100 (See pics.). Cartridge is a GE VR
R-3 Chassis # 6981
As I have the speakers from a 3 channel Motorola (Golden Voice 15" by Jensen and the smaller mid and tweeter) I wasn't too worried about the speaker at this point.
The cabinet is the "WARWICK".
Tested all the tubes. All tubes except 1-6ba6, 12at7,12au7, 6ab4, 5u4gb, and 6e5 are RCA with date code of 1-26 or 1-38. The 1-6ba6 is a Tung-Sol, the 6ab4 is a Raytheon, 12at&U7 are Sylv, and the 6E5 and 5u4 are GE with dates from 1951 to 1961. The 4-6V6's all tested very weak to weak on the EICO 625 (6 to 34).
Broke (unintentionally) the 7K-5W Resistor between the 1st can cap and 2nd can cap. I've got a 5 and 2K 10W to put in for testing until I can get the correct one for final use.
This R-3 is totally original underneath. DRY Electrolytics, and a shitpot of Bumblebee's. Now all I need to do is to figure out what they are (relearn).
The cabinet has some nicks and scrapes on the lower sides. The top has some sun bleaching but I think I can get most of it out with Howards. If not, then a total refinish.
I'll start on the chassis 1st and get it running. then work on the cabinet over the winter.
Gonna be a fair amount of pics
Larry
R-3 Chassis # 6981
Larry
