#1
DIY Simple Active Preamp
I was looking into making a simple preamp I considered the Pass B1 Buffer but was worried if it would have enough gain.
I decided to make one out of parts I had and make it as simple as possible. I used a pretty standard design which I found on Rod Elliot's site, I simplified it greatly so now it has few parts and only one film cap in it, the opamp I used is a AD823. ![]() I etched a PCB and assembled it and tested it out, surprisingly it worked first time. It has too much gain, I am going to change out the 100k resistor in the feedback loop to a lower value which should take care of that. I hooked it up between my phono stage and the main amp inputs of my Yamaha CR-1020 and then did a comparison with the Yammy using it's preamp. The bass is much more extended for a start the sound being more full bodied and open it should improve once it burns in as I used a 2.2uf Panasonic ECW-F polypropylene which may open more up after some hours. Initially it sounds much better than the pre in the Yamaha, the acid test is going to be when I try it in my main setup and put it up against my Yamaha C4 but the way it sounds now it might just be better.
__________________
Benz Micro Ace / Pro-Ject Perspective II, Speed Box II, HypnoToad AD797 MC PhonoStage, Nakamichi 482Z, Yamaha C4, Yamaha M2, Polk SDA 1C. Last edited by HypnoToad; 10-30-2011 at 03:13 PM. |
#2
![]() ![]() You knew that was coming....
__________________
"Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities; Truth isn't." - Mark Twain |
#3
Don't laugh I just threw it together to see if it worked.
__________________
Benz Micro Ace / Pro-Ject Perspective II, Speed Box II, HypnoToad AD797 MC PhonoStage, Nakamichi 482Z, Yamaha C4, Yamaha M2, Polk SDA 1C. |
#5
After some adjustments I still have plenty of gain and listening to Grover Washington Jr - Strawberry Moon and my bedroom system has never sounded so good. With a little burn in time it got a whole lot better.
More air around the instruments and bass to die for, I am thinking of putting one in a case with a 3 input switch including the phono stage so it can run off the same batteries using decent components, my volume control is a ratshack one. Simple seems to better. But the sound is amazing a huge jump from the internal Yamaha preamp, still haven't tried it against my C4 but I am pretty sure of the result already. ![]() You can build one of these really cheaply.
__________________
Benz Micro Ace / Pro-Ject Perspective II, Speed Box II, HypnoToad AD797 MC PhonoStage, Nakamichi 482Z, Yamaha C4, Yamaha M2, Polk SDA 1C. Last edited by HypnoToad; 10-30-2011 at 08:05 PM. |
| Audiokarma |
#6
very cool
#7
This is great! You have to give this a name! I'm gonna try it, though I'll use point to point wiring cuz I've never etched a board. I have the ESP P05 board that I could use instead of 9V batteries..
__________________
Magnestand MMG's. Yamaha M4, ForeplayII line stage and Bugle phono pre. Sansui SR 717 TT with OM/ Digitrac cart. Yamaha DV-S5860 muilti player. |
#8
It's the Simple Preamp or SP.
I changed a few things, I put in 51k resistors instead of the 100k in the feedback loop and changed out the 1.5k for some 27k in the input. I would also use a 250k pot instead of the 100k as it builds up volume very quickly. I am going to try one as soon as I get on to a decent one reasonably priced. You could also try a nice axial 2.2uf cap as well, although for the money the Panasonic's are very good. I also put some polar 47uf caps from the op amp supply rails to ground with some 0.1uf bypass caps on them for stability and low noise.
__________________
Benz Micro Ace / Pro-Ject Perspective II, Speed Box II, HypnoToad AD797 MC PhonoStage, Nakamichi 482Z, Yamaha C4, Yamaha M2, Polk SDA 1C. Last edited by HypnoToad; 10-30-2011 at 09:49 PM. |
#9
I did not realize that a pre-amp could be done so simply. Very interesting. I agree that simple is better. I prefer not to have tone controls, multiple inputs, etc. I have never DIY'd anything but this project has got me thinking
In post #1 you mentioned that you simplified the base design, in what ways did you simplify?What software do you use to make the schematic? |
#10
Cool project. Bonus point on the minimalism. I have a class-A power buffer amp project with the same general vision. I should kickstart it this fall/winter; been sitting on shelves for some time despite having most parts.
All you need is a good enclosure and it will look as good as it sounds! az
__________________
AE Lambda TD15M ***Now with phase plugs! *** in 5ft^3 vented cabinets + BMS 4550 on QSC waveguide + miniDSPUpcoming: Peerless 830869 + BMS 4540ND + JBL 6" mini-PT |
| Audiokarma |
#11
Hey Toad, wanna do a group board offer???
Cheers, Bob |
#12
Quote:
I removed the balance control and took out some other parts in the output, it resembles the output stage of the CNC now. I just wanted something simple to see if it would work, I measured the outputs and there is no DC. It's virtually just a low gain stage with a volume control at the front. You can add different inputs if you like. I am still not sure about the volume control as it is very sensitive. If anyone has any ideas about implementing it better let me know.
__________________
#13
Quote:
#14
search J-fet BOZ, (Bride of Zen) over on DIY... nice, gain, very simple...
Russellc
__________________
Scillia/Merrill modded AR The Turntable w/Magnepan Unitrac, SAE 1000LT, Shure V15Vxmr. AVA Super Pass III, DIY Pass B-1, DIY Pass F-5, DIY P-P 6550, JBL 6230. Indignias, Econowave: JBL 4507w/2235H, QSC152 & B&C DE 250, Altec A-7, Aria 5. MR67, FM3, Mit. DA-F10, Rotel 971 |
#15
Aside from an abundance of caution, there's really no reason to use an output DC-blocking cap in op-amp circuits with such low gain. You could eliminate that item unless you expect to be using op-amps with substantial input offset voltage. Even in that case, you might be better off with an offset trimmer.
__________________
Illegitimi non carborundum! |
| Audiokarma |
| Thread Tools | |
| Display Modes | |
